Print at Aug 15, 2026, 8:08:26 PM View all posts in this thread on one page
Posted by k1r2t3n at Apr 25, 2018, 11:50:55 AM
Floor Textures with gaps from lower level walls
Hi there,
I would appreciate your help:
I am currently building our new home in sweet home and started to apply textures. unfortunately the textures seem to show gaps where the lower level walls are. see screenshot. What is wrong?
https://www.dropbox.com/s/d59csregk2kk5id/gapsintextures.png?dl=0
thank you.
Kirsten
Posted by dorin at Apr 25, 2018, 8:50:23 PM
Re: Floor Textures with gaps from lower level walls
What is wrong?
The height of walls in level UG are at least as the elevation of the level EG.
Solution:
Verify the height of walls on level UG and reduce them.
or
Increase the elevation of level EG.
PS Don't forget: every level have a floor thickness; You must take it in consideration.
Posted by k1r2t3n at Apr 25, 2018, 9:12:56 PM
Dear Dorin,
thank you! I added another 1cm to the elevation. This did the trick!
Perfect!
Cheers, Kirstne
