Total posts in this thread: 4
Previous Thread This topic has been viewed 9487 times and has 3 replies Next Thread
Jxdust
Change font size in dimension numbers
Hello everybody,
Can you change the font size of the numbers in the dimension specification? In my plan, I can change the font size of the numbers of the area specification (Ctrl + Alt + K), but not the font size of the numbers in the dimension specification. And this is so small that you can hardly see it..
Greetings
Jürgen
[Jan 25, 2017, 10:35:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Change font size in dimension numbers
That should be the same shortcut. Did you try Plan > Modify text size > Increase size menu item after selecting the dimension lines?
[Jan 25, 2017, 7:59:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Anakowi
Australia
I have a similar query... using MacOS I see the option in the PLAN menu and the keyboard shortcut is ^⌘+ BUT I'm not sure which keypress to use for "caret" the first symbol?
[Oct 2, 2018, 3:17:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe you have an old keyboard, but on mine, the symbol ^ is written at the top the control key.
[Oct 2, 2018, 8:24:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
