Print at Sep 6, 2026, 4:04:20 AM View all posts in this thread on one page
Posted by Jxdust at Jan 25, 2017, 10:35:07 AM
Change font size in dimension numbers
Hello everybody,
Can you change the font size of the numbers in the dimension specification? In my plan, I can change the font size of the numbers of the area specification (Ctrl + Alt + K), but not the font size of the numbers in the dimension specification. And this is so small that you can hardly see it..
Greetings
Jürgen
Posted by Puybaret at Jan 25, 2017, 7:59:00 PM
Re: Change font size in dimension numbers
That should be the same shortcut. Did you try Plan > Modify text size > Increase size menu item after selecting the dimension lines?
Posted by Anakowi at Oct 2, 2018, 3:17:25 PM
I have a similar query... using MacOS I see the option in the PLAN menu and the keyboard shortcut is ^⌘+ BUT I'm not sure which keypress to use for "caret" the first symbol?
Posted by Puybaret at Oct 2, 2018, 8:24:42 PM
Maybe you have an old keyboard, but on mine, the symbol ^ is written at the top the control key.
