Previous Thread This topic has been viewed 8524 times and has 2 replies Next Thread
anthony_linac
Water tank, plumbing, stove and flue
I have never used this software before so I am a complete amateur. I am looking to design a fireplace for my house. It contains an inset wood burning stove. The flue from the stove goes up through the ceiling and into the bathroom, then out through a wall. A water tank will be positioned directly above the stove. I need to experiment with positioning of the stove and flue, design the water tank and also design a support for them (this will involve brick piers built from the basement up through the chamber floor and RSJ's to support the heavy items. New layouts of the bathroom will be required to accommodate the flue. I will need to model joists between floors as the flue must run between these. Is it possible to design this kind of structural detail in this software? If not, maybe it can help me with certain aspects, and perhaps someone could recommend other software to carry out the more structural elements. Thanks
[Nov 15, 2015, 10:13:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Water tank, plumbing, stove and flue
Perfectly possible to design with SH3D. And although not very difficult, you need to familiarise yourself with levels, finding models and using cylinders etc for flue. I you look through the forum, you may also find specific hints (such as placing joists in thread 6255).
Good luck. ok
[Nov 16, 2015, 9:30:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wickscool
It sounds like you’re planning a complex and interesting project involving a stove, flue, water tank, and structural modifications. Most architectural design or CAD software like SketchUp, Revit, or FreeCAD can help with layout planning, experimenting with stove and flue positioning, and basic structural elements like joists and supports. However, for detailed structural engineering (like RSJs, brick piers from basement to floor, and load calculations), these tools may be limited unless used with plugins or paired with structural analysis software like SAP2000, Tekla Structures, or AutoCAD Structural Detailing.
If you're a beginner, SketchUp might be the easiest to start with. It allows for good 3D visualization and experimenting with positioning. For structural accuracy, consulting an engineer or using specialized structural design software would be best.
Français :
Il semble que vous planifiez un projet complexe et intéressant impliquant un poêle, un conduit de fumée, un réservoir d’eau et des modifications structurelles. La plupart des logiciels de conception architecturale ou de CAO comme SketchUp, Revit ou FreeCAD peuvent vous aider à planifier l’agencement, à expérimenter le positionnement du poêle et du conduit, ainsi qu’à modéliser des éléments de structure de base comme les solives et les supports. Cependant, pour les détails structurels avancés (poutres RSJ, piliers en briques du sous-sol au plancher, calculs de charge), ces logiciels peuvent être limités sans plugins spécifiques, ou nécessitent d’être combinés à un logiciel d’analyse structurelle comme SAP2000, Tekla Structures ou AutoCAD Structural Detailing.
Si vous êtes débutant, SketchUp est probablement le plus simple pour commencer. Il permet une bonne visualisation 3D et des tests de positionnement. Pour une précision structurelle, il serait préférable de consulter un ingénieur ou d’utiliser un logiciel spécialisé.
[Apr 5, 2025, 1:59:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
