Total posts in this thread: 5
Previous Thread This topic has been viewed 4777 times and has 4 replies Next Thread
turbokey
Furniture Library editor shows nothing
Hi! Importing a furniture library onto the program doesn't take any effect onto the furniture window. I can see the file is copied to application data\... folder but SH3d doesnt see nothing new, just the default library.
Also, when I try to see an external library, like Contributions.sh3f file using Furniture Editor, it doesnt show nothing too. What can I do? :(
Using W7 SP1.
[Aug 30, 2015, 10:12:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Furniture Library editor shows nothing
Did you try with a smaller library?
[Sep 1, 2015, 8:23:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
turbokey
Thanks Emmanuel. Tried LucaPresidente.sh3f (89 models) and Trees.sh3f (7 models) files and got the same results, like the screenshot.
[Sep 2, 2015, 12:46:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Try to launch the following command in a command window:
java -jar C:\FurnitureLibraryEditor-1.17.jar
(to get the right path of FurnitureLibraryEditor-1.17.jar file, just drag and drop its file icon in the command window).
When the bug happens, some text reporting an exception should appear in the command window. If you could copy/paste that text, it would be helpful.
[Sep 4, 2015, 12:20:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
turbokey
Tried and nothing special happens on command window :(
[Sep 4, 2015, 7:36:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
