Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Furniture Library editor shows nothing |
| Print at Sep 6, 2026, 5:56:59 AM | View all posts in this thread on one page |
| Posted by turbokey at Aug 30, 2015, 10:12:22 AM |
Furniture Library editor shows nothing Hi! Importing a furniture library onto the program doesn't take any effect onto the furniture window. I can see the file is copied to application data\... folder but SH3d doesnt see nothing new, just the default library. Also, when I try to see an external library, like Contributions.sh3f file using Furniture Editor, it doesnt show nothing too. What can I do? :( ![]() Using W7 SP1. |
| Posted by Puybaret at Sep 1, 2015, 8:23:08 PM |
Re: Furniture Library editor shows nothing Did you try with a smaller library? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by turbokey at Sep 2, 2015, 12:46:53 AM |
Re: Furniture Library editor shows nothing Thanks Emmanuel. Tried LucaPresidente.sh3f (89 models) and Trees.sh3f (7 models) files and got the same results, like the screenshot. |
| Posted by Puybaret at Sep 4, 2015, 12:20:51 AM |
Re: Furniture Library editor shows nothing Try to launch the following command in a command window: java -jar C:\FurnitureLibraryEditor-1.17.jar When the bug happens, some text reporting an exception should appear in the command window. If you could copy/paste that text, it would be helpful. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by turbokey at Sep 4, 2015, 7:36:26 AM |
Re: Furniture Library editor shows nothing Tried and nothing special happens on command window :( ![]() |
Current timezone is GMT Sep 6, 2026, 5:56:59 AM |
