door size jumps, if I move into the wall
Hello,
I have door with W/D/H 96/96/200. Everytimes, I move into a wall with 25 cm depth, the Depth of door switches to 226,7!?? Even when I check Proportion hold. What I'm doing wrong? Another questioon. Two walls are "melted" ( slope blue line). How can I revert it?
Re: door size jumps, if I move into the wall
About the issue with the door, please read the workaround proposed in this ticket.
About the "melted" walls, I'm not sure to fully understand what you mean. If you have two walls that are superimposed in the plan and you want to remove one, maybe you could right click on the walls and choose the one you want in the Select object menu that will appear in the contextual menu. Then just delete the selected one.
Hi, thank you for the link.
What I mean is in the snapshot. What is the difference between the horizontal and the slope divider? My problem is, when I try to resize the lower wall to the right, I have to get into account half of the wall thickness. It dont't work. I need a little bit of explanation.
