Print at Aug 16, 2026, 11:41:40 PM
Posted by Puybaret at Aug 17, 2015, 9:11:02 AM
Re: door size jumps, if I move into the wall
About the issue with the door, please read the workaround proposed in this ticket.
About the "melted" walls, I'm not sure to fully understand what you mean. If you have two walls that are superimposed in the plan and you want to remove one, maybe you could right click on the walls and choose the one you want in the Select object menu that will appear in the contextual menu. Then just delete the selected one.
