Re: Can I prioritize/bring to front an object?
There is another workaround possible.
Let's assume your counter top is 4 centimeters thick. - Using very thin walls with 4 cms height, trace the outline of the countertop. - Create a room inside the walls - Export, then import your kitchen sink, and make sure to check the Staircase checkbox during importation. - When you insert the sink, it will cut out a hole in the ceiling/floor. - Create a new level and adjust elevations so that things line up properly, and the sink is flush with the counter top. - Export the whole thing and import it as a normal piece of furniture. - Place it on top of (a) kitchen cabinet(s) without a counter top.
It's a bit complicated to do it this way, and it may be easier to use existing models.
[Mar 4, 2014, 4:15:36 PM]
[Link]
