Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can I prioritize/bring to front an object? » » » » Post: Re: Can I prioritize/bring to front an object? |
Print at Aug 22, 2026, 3:20:51 AM |
| Posted by hansmex at Mar 4, 2014, 4:15:36 PM |
Re: Can I prioritize/bring to front an object? There is another workaround possible. Let's assume your counter top is 4 centimeters thick. - Using very thin walls with 4 cms height, trace the outline of the countertop. - Create a room inside the walls - Export, then import your kitchen sink, and make sure to check the Staircase checkbox during importation. - When you insert the sink, it will cut out a hole in the ceiling/floor. - Create a new level and adjust elevations so that things line up properly, and the sink is flush with the counter top. - Export the whole thing and import it as a normal piece of furniture. - Place it on top of (a) kitchen cabinet(s) without a counter top. It's a bit complicated to do it this way, and it may be easier to use existing models. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 22, 2026, 3:20:51 AM |
