Total posts in this thread: 9
Previous Thread This topic has been viewed 7148 times and has 8 replies Next Thread
SnakeGB
Create Photo Hangs
I have a problem with Create photo, when I click to render it just sits there with the spinning arrow in the centre, I have left this for hours and still nothing, if I click stop it also will not respond.
i am running windows 7 64bit with a 4.1 cpu
Help!
Thanks
[Feb 24, 2014, 12:26:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Create Photo Hangs
Maybe you encountered a bug. Could you send me your file to check it?
[Feb 25, 2014, 9:28:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SnakeGB
sure but its a big file,
its 74mb rared
still want me to send it?
[Feb 25, 2014, 8:23:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Don't worry for the size wink
[Feb 26, 2014, 12:25:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your file. I could start the rendering with no problem. This is probably an issue with the max memory used by the program that you should increase.
[Feb 26, 2014, 6:36:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SnakeGB
Thanks for checking it for me, its definitely a memory issue because if i create a small room from fresh it works.
am i correct here ive created the ini file and all i put in is this
"-Xmx1024m"
ive also tried "-Xmx3072m"
both do not create photo
my system has 8GB memory and it windows 7
Thanks
[Feb 26, 2014, 7:51:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SnakeGB
with it set to 3072m it crashed completely
here is the error log
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000006d9001d4, pid=4276, tid=3096
# JRE version: 6.0_45-b06
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.45-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# V [jvm.dll+0xd01d4]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x0000000000522800): VMThread [stack: 0x0000000006220000,0x0000000006320000] [id=3096]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000000004000
Registers:
RAX=0x0000000000004000, RBX=0x0000000000004000, RCX=0x0000000000000000, RDX=0x0000000000000105
RSP=0x000000000631f870, RBP=0x00000000bc80c170, RSI=0x00000000dc967064, RDI=0x00000000bc80c168
R8 =0x0000000000000005, R9 =0x0000000019661c70, R10=0x00000000000001fe, R11=0x0000000000000000
R12=0x00000000dc966fa0, R13=0x000000000021ce00, R14=0x0000000000474120, R15=0x0000000000000012
RIP=0x000000006d9001d4, EFLAGS=0x0000000000010206
Top of Stack: (sp=0x000000000631f870)
0x000000000631f870: 00000000e11003d8 000000006d944740
0x000000000631f880: 0000000000000003 00000000bc15e798
0x000000000631f890: 00000000dc96704c 000000006d91e31a
0x000000000631f8a0: 0000000000000003 0000000000473000
0x000000000631f8b0: 0000000019661c70 000000000021a600
0x000000000631f8c0: 0000000000473000 000000006da8430b
0x000000000631f8d0: 00000000dc966fa0 0000000000000000
0x000000000631f8e0: 000000000021a600 0000000019661c70
0x000000000631f8f0: 0000000000473000 000000006dbf9ef0
0x000000000631f900: 0000000000000000 0000000000472f70
0x000000000631f910: 000000000021a600 000000006df4f230
0x000000000631f920: 0000000000467e00 000000006dc07a42
0x000000000631f930: 000000006ddfe148 0000000000000000
0x000000000631f940: 000000006df4f230 0000000000000c01
0x000000000631f950: 0000000000010100 0000000000000000
0x000000000631f960: 000000000052a000 0000000000000000
Instructions: (pc=0x000000006d9001d4)
0x000000006d9001b4: ec 20 8b 01 85 c0 0f 84 7e 01 00 00 0f b6 0d 79
0x000000006d9001c4: 90 63 00 48 8b d8 48 d3 e3 48 03 1d 64 90 63 00
0x000000006d9001d4: 48 8b 03 24 03 3c 03 0f 84 5d 01 00 00 48 8b 13
0x000000006d9001e4: 48 c7 44 24 30 03 00 00 00 48 8b 44 24 30 48 89
Register to memory mapping:
RAX=0x0000000000004000 is an unknown value
RBX=0x0000000000004000 is an unknown value
RCX=0x0000000000000000 is an unknown value
RDX=0x0000000000000105 is an unknown value
RSP=0x000000000631f870 is an unknown value
RBP=0x00000000bc80c170 is an oop
java.lang.Class
- klass: 'java/lang/Class'
RSI=0x00000000dc967064 is an oop
javax.media.j3d.GroupRetained
- klass: 'javax/media/j3d/GroupRetained'
RDI=0x00000000bc80c168 is an oop
{instance class}
- klass: {other class}
R8 =0x0000000000000005 is an unknown value
R9 =0x0000000019661c70 is an unknown value
R10=0x00000000000001fe is an unknown value
R11=0x0000000000000000 is an unknown value
R12=0x00000000dc966fa0 is an oop
R13=0x000000000021ce00 is an unknown value
R14=0x0000000000474120 is an unknown value
R15=0x0000000000000012 is an unknown value
Stack: [0x0000000006220000,0x0000000006320000], sp=0x000000000631f870, free space=1022k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V [jvm.dll+0xd01d4]
VM_Operation (0x000000001310f240): ParallelGCFailedAllocation, mode: safepoint, requested by thread 0x0000000007f71800
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0000000007f72000 JavaThread "pool-13-thread-1" [_thread_blocked, id=5320, stack(0x0000000013270000,0x0000000013370000)]
0x0000000007f71800 JavaThread "Image Animator 3" daemon [_thread_blocked, id=6112, stack(0x0000000013010000,0x0000000013110000)]
0x0000000007f70800 JavaThread "J3D-InputDeviceScheduler-4" [_thread_blocked, id=2728, stack(0x0000000025e30000,0x0000000025f30000)]
0x0000000007f70000 JavaThread "J3D-SoundSchedulerUpdateThread-4" [_thread_blocked, id=3280, stack(0x0000000022c90000,0x0000000022d90000)]
0x0000000007f6f000 JavaThread "J3D-RenderStructureUpdateThread-4" [_thread_blocked, id=4332, stack(0x0000000022b90000,0x0000000022c90000)]
0x0000000007f6e800 JavaThread "J3D-BehaviorScheduler-4" [_thread_blocked, id=6128, stack(0x0000000022a90000,0x0000000022b90000)]
0x0000000007f6e000 JavaThread "J3D-TransformStructureUpdateThread-4" [_thread_blocked, id=6008, stack(0x0000000022990000,0x0000000022a90000)]
0x0000000007f6d000 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-4" [_thread_blocked, id=1056, stack(0x0000000022890000,0x0000000022990000)]
0x0000000006e7d000 JavaThread "J3D-SoundStructureUpdateThread-4" [_thread_blocked, id=5012, stack(0x00000000221d0000,0x00000000222d0000)]
0x0000000006e7e000 JavaThread "J3D-GeometryStructureUpdateThread-4" [_thread_blocked, id=5536, stack(0x00000000219d0000,0x0000000021ad0000)]
0x0000000007e26800 JavaThread "J3D-BehaviorStructureUpdateThread-4" [_thread_blocked, id=1776, stack(0x0000000015160000,0x0000000015260000)]
0x0000000006e7c800 JavaThread "pool-11-thread-1" [_thread_blocked, id=1528, stack(0x00000000211d0000,0x00000000212d0000)]
0x0000000006e7c000 JavaThread "J3D-InputDeviceScheduler-3" [_thread_blocked, id=3100, stack(0x0000000020fd0000,0x00000000210d0000)]
0x0000000006e7b000 JavaThread "J3D-SoundSchedulerUpdateThread-3" [_thread_blocked, id=6024, stack(0x0000000020ed0000,0x0000000020fd0000)]
0x0000000006e7a800 JavaThread "J3D-RenderStructureUpdateThread-3" [_thread_blocked, id=3736, stack(0x0000000020dd0000,0x0000000020ed0000)]
0x0000000006e79800 JavaThread "J3D-BehaviorScheduler-3" [_thread_blocked, id=5632, stack(0x0000000015d00000,0x0000000015e00000)]
0x0000000006e79000 JavaThread "J3D-TransformStructureUpdateThread-3" [_thread_blocked, id=5288, stack(0x0000000015c00000,0x0000000015d00000)]
0x0000000006e78000 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-3" [_thread_blocked, id=5504, stack(0x0000000015b00000,0x0000000015c00000)]
0x0000000006e77800 JavaThread "J3D-SoundStructureUpdateThread-3" [_thread_blocked, id=2504, stack(0x00000000157d0000,0x00000000158d0000)]
0x0000000006e76800 JavaThread "J3D-GeometryStructureUpdateThread-3" [_thread_blocked, id=5608, stack(0x0000000015360000,0x0000000015460000)]
0x0000000007e2a000 JavaThread "J3D-BehaviorStructureUpdateThread-3" [_thread_blocked, id=2740, stack(0x0000000015260000,0x0000000015360000)]
0x0000000007e24800 JavaThread "J3D-MasterControl-5" [_thread_blocked, id=5300, stack(0x0000000015060000,0x0000000015160000)]
0x0000000007e28800 JavaThread "J3D-NotificationThread" [_thread_blocked, id=5640, stack(0x0000000014f60000,0x0000000015060000)]
0x0000000007e23800 JavaThread "J3D-TimerThread" [_thread_blocked, id=6040, stack(0x0000000014d20000,0x0000000014e20000)]
0x0000000007e25000 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=1784, stack(0x0000000014c20000,0x0000000014d20000)]
0x0000000007e23000 JavaThread "pool-9-thread-4" [_thread_blocked, id=5708, stack(0x00000000156d0000,0x00000000157d0000)]
0x0000000007a1a000 JavaThread "pool-9-thread-3" [_thread_blocked, id=1900, stack(0x00000000155d0000,0x00000000156d0000)]
0x0000000007a1a800 JavaThread "pool-9-thread-2" [_thread_blocked, id=5136, stack(0x00000000141d0000,0x00000000142d0000)]
0x0000000007a25800 JavaThread "pool-9-thread-1" [_thread_blocked, id=4432, stack(0x000000000be20000,0x000000000bf20000)]
0x0000000007a22800 JavaThread "pool-8-thread-4" [_thread_blocked, id=5656, stack(0x000000000bd20000,0x000000000be20000)]
0x0000000007a24800 JavaThread "pool-8-thread-3" [_thread_blocked, id=5732, stack(0x000000000bc20000,0x000000000bd20000)]
0x0000000007a24000 JavaThread "pool-8-thread-2" [_thread_blocked, id=4768, stack(0x000000000bb20000,0x000000000bc20000)]
0x0000000007a23800 JavaThread "pool-8-thread-1" [_thread_blocked, id=4092, stack(0x000000000b720000,0x000000000b820000)]
0x0000000007e28000 JavaThread "Thread-8" [_thread_blocked, id=4824, stack(0x0000000014b20000,0x0000000014c20000)]
0x0000000007e26000 JavaThread "pool-6-thread-1" [_thread_blocked, id=5356, stack(0x0000000013b20000,0x0000000013c20000)]
0x0000000007a22000 JavaThread "pool-4-thread-8" [_thread_blocked, id=5512, stack(0x0000000012f10000,0x0000000013010000)]
0x0000000007a21000 JavaThread "pool-4-thread-7" [_thread_blocked, id=4260, stack(0x0000000012e10000,0x0000000012f10000)]
0x0000000007a20800 JavaThread "pool-4-thread-6" [_thread_blocked, id=3244, stack(0x0000000012d10000,0x0000000012e10000)]
0x0000000007a1f800 JavaThread "pool-4-thread-5" [_thread_blocked, id=5900, stack(0x0000000012c10000,0x0000000012d10000)]
0x0000000007a1f000 JavaThread "pool-4-thread-4" [_thread_blocked, id=3732, stack(0x0000000012b10000,0x0000000012c10000)]
0x0000000007a1d800 JavaThread "pool-4-thread-3" [_thread_blocked, id=5784, stack(0x0000000011fe0000,0x00000000120e0000)]
0x0000000007a1d000 JavaThread "pool-4-thread-2" [_thread_blocked, id=4452, stack(0x000000000fe40000,0x000000000ff40000)]
0x0000000007a1c000 JavaThread "TimerQueue" daemon [_thread_blocked, id=4248, stack(0x000000000fd40000,0x000000000fe40000)]
0x0000000007a1b800 JavaThread "pool-4-thread-1" [_thread_blocked, id=5832, stack(0x000000000fc40000,0x000000000fd40000)]
0x0000000007a19000 JavaThread "DestroyJavaVM" [_thread_blocked, id=5616, stack(0x0000000002440000,0x0000000002540000)]
0x0000000007a18800 JavaThread "autoSaveTimer" daemon [_thread_blocked, id=5556, stack(0x000000000f920000,0x000000000fa20000)]
0x0000000007a17800 JavaThread "Timer-1" daemon [_thread_blocked, id=5380, stack(0x000000000f820000,0x000000000f920000)]
0x0000000007a17000 JavaThread "Timer-0" daemon [_thread_blocked, id=6048, stack(0x000000000f720000,0x000000000f820000)]
0x0000000007a16800 JavaThread "J3D-Renderer-1" [_thread_blocked, id=3984, stack(0x000000000bf20000,0x000000000c020000)]
0x00000000065b1800 JavaThread "pool-2-thread-1" [_thread_in_native, id=3612, stack(0x000000000b820000,0x000000000b920000)]
0x0000000006d4f800 JavaThread "D3D Screen Updater" daemon [_thread_in_native, id=3944, stack(0x000000000b620000,0x000000000b720000)]
0x0000000006d30800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=4848, stack(0x0000000009c60000,0x0000000009d60000)]
0x0000000006d83800 JavaThread "AWT-Windows" daemon [_thread_blocked, id=2916, stack(0x0000000008490000,0x0000000008590000)]
0x0000000006d82800 JavaThread "AWT-Shutdown" [_thread_blocked, id=2776, stack(0x0000000008390000,0x0000000008490000)]
0x000000000651e800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4868, stack(0x0000000007800000,0x0000000007900000)]
0x0000000006485800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=4712, stack(0x0000000006b20000,0x0000000006c20000)]
0x0000000006482000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=5652, stack(0x0000000006a20000,0x0000000006b20000)]
0x000000000647d800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=1700, stack(0x0000000006920000,0x0000000006a20000)]
0x000000000647a000 JavaThread "Attach Listener" daemon [_thread_blocked, id=5340, stack(0x0000000006820000,0x0000000006920000)]
0x0000000006475000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2268, stack(0x0000000006720000,0x0000000006820000)]
0x0000000006425800 JavaThread "Finalizer" daemon [_thread_blocked, id=2032, stack(0x0000000006620000,0x0000000006720000)]
0x000000000052a000 JavaThread "Reference Handler" daemon [_thread_blocked, id=5440, stack(0x0000000006320000,0x0000000006420000)]
Other Threads:
=>0x0000000000522800 VMThread [stack: 0x0000000006220000,0x0000000006320000] [id=3096]
0x000000000649e800 WatcherThread [stack: 0x0000000006c20000,0x0000000006d20000] [id=5436]
VM state:at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x0000000000219800] Threads_lock - owner thread: 0x0000000000522800
[0x0000000000219d00] Heap_lock - owner thread: 0x0000000007f71800
Heap
PSYoungGen total 211264K, used 116544K [0x00000000eaab0000, 0x0000000100000000, 0x0000000100000000)
eden space 116544K, 100% used [0x00000000eaab0000,0x00000000f1c80000,0x00000000f1c80000)
from space 94720K, 0% used [0x00000000fa380000,0x00000000fa380000,0x0000000100000000)
to space 116480K, 0% used [0x00000000f1c80000,0x00000000f1c80000,0x00000000f8e40000)
PSOldGen total 699072K, used 699047K [0x00000000c0000000, 0x00000000eaab0000, 0x00000000eaab0000)
object space 699072K, 99% used [0x00000000c0000000,0x00000000eaaa9f48,0x00000000eaab0000)
PSPermGen total 35328K, used 35064K [0x00000000bae00000, 0x00000000bd080000, 0x00000000c0000000)
object space 35328K, 99% used [0x00000000bae00000,0x00000000bd03e188,0x00000000bd080000)
Code Cache [0x0000000002540000, 0x0000000002d40000, 0x0000000005540000)
total_blobs=2681 nmethods=1884 adapters=748 free_code_cache=42202240 largest_free_block=81728
Dynamic libraries:
0x0000000000400000 - 0x000000000042f000 C:\Program Files\Sweet Home 3D\jre6\launch4j-tmp\SweetHome3D.exe
0x0000000077aa0000 - 0x0000000077c49000 C:\Windows\SYSTEM32\ntdll.dll
0x00000000773c0000 - 0x00000000774df000 C:\Windows\system32\kernel32.dll
0x000007fefdfb0000 - 0x000007fefe01c000 C:\Windows\system32\KERNELBASE.dll
0x000007feffb80000 - 0x000007feffc5b000 C:\Windows\system32\ADVAPI32.dll
0x000007fefec00000 - 0x000007fefec9f000 C:\Windows\system32\msvcrt.dll
0x000007feffc60000 - 0x000007feffc7f000 C:\Windows\SYSTEM32\sechost.dll
0x000007fefe970000 - 0x000007fefea9d000 C:\Windows\system32\RPCRT4.dll
0x0000000077630000 - 0x000000007772a000 C:\Windows\system32\USER32.dll
0x000007fefe720000 - 0x000007fefe787000 C:\Windows\system32\GDI32.dll
0x000007fefeb70000 - 0x000007fefeb7e000 C:\Windows\system32\LPK.dll
0x000007fefeaa0000 - 0x000007fefeb69000 C:\Windows\system32\USP10.dll
0x000007fefed00000 - 0x000007fefed2e000 C:\Windows\system32\IMM32.DLL
0x000007fefe610000 - 0x000007fefe719000 C:\Windows\system32\MSCTF.dll
0x000000006d830000 - 0x000000006dfec000 C:\Program Files\Sweet Home 3D\jre6\bin\server\jvm.dll
0x000007fefb020000 - 0x000007fefb05b000 C:\Windows\system32\WINMM.dll
0x000000006d7a0000 - 0x000000006d7ae000 C:\Program Files\Sweet Home 3D\jre6\bin\verify.dll
0x000000006d3c0000 - 0x000000006d3e7000 C:\Program Files\Sweet Home 3D\jre6\bin\java.dll
0x000000006d7f0000 - 0x000000006d802000 C:\Program Files\Sweet Home 3D\jre6\bin\zip.dll
0x000007fefd4d0000 - 0x000007fefd4e7000 C:\Windows\system32\CRYPTSP.dll
0x000007fefd1d0000 - 0x000007fefd217000 C:\Windows\system32\rsaenh.dll
0x000007fefcf40000 - 0x000007fefcf5e000 C:\Windows\system32\USERENV.dll
0x000007fefdf00000 - 0x000007fefdf0f000 C:\Windows\system32\profapi.dll
0x000007fefde30000 - 0x000007fefde3f000 C:\Windows\system32\CRYPTBASE.dll
0x000000006d620000 - 0x000000006d637000 C:\Program Files\Sweet Home 3D\jre6\bin\net.dll
0x000007feffc80000 - 0x000007feffccd000 C:\Windows\system32\WS2_32.dll
0x000007fefe3f0000 - 0x000007fefe3f8000 C:\Windows\system32\NSI.dll
0x000007fefd470000 - 0x000007fefd4c5000 C:\Windows\system32\mswsock.dll
0x000007fefd460000 - 0x000007fefd467000 C:\Windows\System32\wship6.dll
0x000007fefca40000 - 0x000007fefca55000 C:\Windows\system32\NLAapi.dll
0x000007fef92d0000 - 0x000007fef92e5000 C:\Windows\system32\napinsp.dll
0x000007fef92b0000 - 0x000007fef92c9000 C:\Windows\system32\pnrpnsp.dll
0x000007fefd2f0000 - 0x000007fefd34b000 C:\Windows\system32\DNSAPI.dll
0x000007fef8fe0000 - 0x000007fef8feb000 C:\Windows\System32\winrnr.dll
0x0000000072340000 - 0x0000000072366000 C:\Program Files\Bonjour\mdnsNSP.dll
0x000007fefc4d0000 - 0x000007fefc4f7000 C:\Windows\system32\Iphlpapi.DLL
0x000007fefc4c0000 - 0x000007fefc4cb000 C:\Windows\system32\WINNSI.DLL
0x000007fefdaf0000 - 0x000007fefdaf7000 C:\Windows\System32\wshtcpip.dll
0x000007fef9410000 - 0x000007fef9418000 C:\Windows\system32\rasadhlp.dll
0x000007fefc310000 - 0x000007fefc363000 C:\Windows\System32\fwpuclnt.dll
0x000000006d000000 - 0x000000006d1c4000 C:\Program Files\Sweet Home 3D\jre6\bin\awt.dll
0x000007fefae90000 - 0x000007fefaf01000 C:\Windows\system32\WINSPOOL.DRV
0x000007fefe400000 - 0x000007fefe603000 C:\Windows\system32\ole32.dll
0x000007fefedf0000 - 0x000007feffb78000 C:\Windows\system32\SHELL32.dll
0x000007fefeb80000 - 0x000007fefebf1000 C:\Windows\system32\SHLWAPI.dll
0x000007fefc5a0000 - 0x000007fefc794000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\COMCTL32.dll
0x000000006d4e0000 - 0x000000006d515000 C:\Program Files\Sweet Home 3D\jre6\bin\jpeg.dll
0x000007fefb940000 - 0x000007fefb958000 C:\Windows\system32\DWMAPI.DLL
0x000007fefbd20000 - 0x000007fefbd76000 C:\Windows\system32\uxtheme.dll
0x000000006d2a0000 - 0x000000006d315000 C:\Program Files\Sweet Home 3D\jre6\bin\fontmanager.dll
0x000007fef4280000 - 0x000007fef42a1000 C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
0x000007fefdb20000 - 0x000007fefdb31000 C:\Windows\system32\WTSAPI32.dll
0x000007fefcbe0000 - 0x000007fefcc0d000 C:\Windows\system32\ntmarta.dll
0x000007fefeca0000 - 0x000007fefecf2000 C:\Windows\system32\WLDAP32.dll
0x000007feefe60000 - 0x000007fef005f000 C:\Windows\system32\d3d9.dll
0x000007fefdae0000 - 0x000007fefdaec000 C:\Windows\system32\VERSION.dll
0x000007fef8b40000 - 0x000007fef8b47000 C:\Windows\system32\d3d8thk.dll
0x000007feed8c0000 - 0x000007feee99e000 C:\Windows\system32\nvd3dumx.dll
0x0000000077c60000 - 0x0000000077c67000 C:\Windows\system32\PSAPI.DLL
0x000007fefd730000 - 0x000007fefd75c000 C:\Windows\system32\powrprof.dll
0x000007fefe790000 - 0x000007fefe967000 C:\Windows\system32\SETUPAPI.dll
0x000007fefe0c0000 - 0x000007fefe0f6000 C:\Windows\system32\CFGMGR32.dll
0x000007feffcd0000 - 0x000007feffda7000 C:\Windows\system32\OLEAUT32.dll
0x000007fefe100000 - 0x000007fefe11a000 C:\Windows\system32\DEVOBJ.dll
0x000000006d400000 - 0x000000006d407000 C:\Program Files\Sweet Home 3D\jre6\bin\jawt.dll
0x0000000010000000 - 0x000000001003e000 C:\Program Files\Sweet Home 3D\lib\j3dcore-ogl.dll
0x000007fef4e30000 - 0x000007fef4f4d000 C:\Windows\system32\OPENGL32.dll
0x000007fef7290000 - 0x000007fef72bd000 C:\Windows\system32\GLU32.dll
0x000007fef4d30000 - 0x000007fef4e21000 C:\Windows\system32\DDRAW.dll
0x000007fef4d20000 - 0x000007fef4d28000 C:\Windows\system32\DCIMAN32.dll
0x000000000c020000 - 0x000000000de51000 C:\Windows\system32\nvoglv64.DLL
0x000007fefe290000 - 0x000007fefe2c9000 C:\Windows\system32\WINTRUST.dll
0x000007fefe120000 - 0x000007fefe28a000 C:\Windows\system32\CRYPT32.dll
0x000007fefdfa0000 - 0x000007fefdfaf000 C:\Windows\system32\MSASN1.dll
0x000000006d640000 - 0x000000006d64c000 C:\Program Files\Sweet Home 3D\jre6\bin\nio.dll
0x000000006d210000 - 0x000000006d238000 C:\Program Files\Sweet Home 3D\jre6\bin\dcpr.dll
0x000000006d1d0000 - 0x000000006d20d000 C:\Program Files\Sweet Home 3D\jre6\bin\cmm.dll
VM Arguments:
jvm_args: -Xmx1023m -Djava.library.path=lib -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer
java_command: com.eteks.sweethome3d.SweetHome3D
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
PATH=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\CollabNet;C:\Program Files (x86)\Embarcadero\RAD Studio\12.0\bin;C:\Users\Public\Documents\RAD Studio\12.0\Bpl;C:\Program Files (x86)\Embarcadero\RAD Studio\12.0\bin64;C:\Users\Public\Documents\RAD Studio\12.0\Bpl\Win64;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Librariesredistintel64compiler;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:Windows
\System32\WindowsPowerShell\v1.0\;c:\Program Files (x86)\Common Files\Ulead Systems\MPEG;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files\Common Files\Autodesk Shared\;C:\Program Files (x86)\Autodesk\Backburner\;C:\Program Files\Sweet Home 3D\jre6\bin
USERNAME=SnakeGB
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 42 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt
Memory: 4k page, physical 8356836k(4936448k free), swap 16711816k(11435452k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (20.45-b01) for windows-amd64 JRE (1.6.0_45-b06), built on Apr 1 2013 12:31:37 by "java_re" with MS VC++ 8.0 (VS2005)
time: Wed Feb 26 18:49:40 2014
elapsed time: 232 seconds
[Feb 26, 2014, 7:55:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SnakeGB
sorted,
it was a memory issue with java
followed this guide and the issue is now sorted out
http://www.tomshardware.co.uk/faq/id-1761312/...irtual-machine-issue.html
[Feb 28, 2014, 5:34:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
[email protected]
mac powerbook 10.7.5, 2.2 intel core i7, 16 gb 1333 MHz ddr3, L2 Cache (per Core):256 KB, L3 Cache:6 MB, AMD Radeon HD 6750M
SweetHome3D-4.4 is what i downloaded and am using - no other plug-ins
i created the home, but everything suddendly slowed down, seems right after i added trees and bushes
i cannot create a decent video - even after keeping the size, etc., to bare minimum
i have not been able to create a photo at all
i cleared the hard drive of everything possible - now have 141 GB available of 500.
bought and doubled the RAM to 16 gb
tried to do this:
Under Mac OS X, right click on the application icon of Sweet Home 3D, select Show Package Contents, open the Contents folder, edit the Info.plist file by dragging its icon on TextEdit application, update the 1024 value in the text <string>-Xmx1024m</string>, save the file, then relaunch Sweet Home 3D.
tried to change <string>-Xmx1024m</string> to <string>-Xmx2048m</string>
when i open the Info.plist file in text edit... i cannot change it because it is locked.
i went to "info" and that does not allow me to unlock the file to make the change
any suggestions?
do i need to be using some plug-in to help with creating photos and videos?
thank you very much,
david
[Aug 29, 2014, 5:19:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
