Total posts in this thread: 4
Previous Thread This topic has been viewed 3068 times and has 3 replies Next Thread
kempher
terrace, hanged wall
Hi, i am a newbie in this forum, may somebody can help me. How to create a hanged wall in terrace up side, because i try to make it with the wall, not feature to change elevation which is can make the wall move higher, i need solution an thank you crying
[Dec 16, 2013, 8:53:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: terrace, hanged wall
Provided I understand your question, how about: Either create a new level where you want the wall to be elevated, or use an invisible box or opening to remove the lower part of the wall.
[Dec 16, 2013, 12:49:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kempher
Thank's man, i'll try to find 3d model of invisible box, recommended extention file of invisible box may .obj or....?
[Dec 17, 2013, 2:56:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Creating an elevated level (even if it is just for that wall) would be my preferred solution.
For a box, you can use this (zipped .obj - drag drop into plan) - just make sure you import it as a door/window so it cuts a hole in your wall.
[Dec 17, 2013, 3:37:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
