Posts: 13   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 11563 times and has 12 replies Next Thread
Re: Importing 3d Models
Beverly,
While in Sketchup go to File -> Export -> 3D Model -> Options and make sure that Export Texture Maps is checked.
I haven't found a way to get rid of the black lines.
[Dec 14, 2013, 6:46:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As the model imports correctly here (well, shades of blue and green legs, but with your texture), hansmex' solution should do the trick.
However, I see your colour names are in angle brackets. The brackets should be converted when you export, but could cause problems. As a precaution, I would rename the materials (in Sketchup: write a new name over the old one and press enter). In general, try to use plain text names with numbers, avoid spaces and all other characters.
As for the black lines (the edges), they should not show in SH3D import (unless they are drawn in thin air or on a flat surface). But you can "remove" the lines in Sketchup too (Window - Soften Edges - in the case of this model, you would need to explode the groups/elements many times to select all elements at the same time).
[Dec 14, 2013, 10:33:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enmnomad
Thank you for your attention to my pink furniture dilemma, and please accept my apology for taking up your time. Hopefully, I've found a solution. I uninstalled and then reinstalled SketchUp, and the next piece of furniture came through fine. Apparently the problem was on that end and not with SH3D. I've tried a number of floorplan programs, none of which come close to SH3D.
[Dec 14, 2013, 7:19:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
