Re: Sweet Home 3D 4.2
Thanks for the new version! Although the checkbox "check for updates" was enabled in my 4.1.-Version, the software did not inform me about the new release. Even hitting the "check now" button did not help. Maybe this was a bug in 4.1. ?
Spain
m@, if you re-read a few posts above you'll see that version 4.2 is currently on beta stage.
---------------------------------------- If a long walk every day were healthy, mailmen would be immortal.
m@, the updates check feature displays a message coming from the web server. As there's always a risk to miss a last big issue, I prefer not to rush to inform every users when I release a new version, and updated this update message only tonight (thanks for recalling me anyway). It should work now.
Spain
Oops. So it was me who missed the important post. And when I say "the post" I mean just the post, because I read the later post by Hansmex about the problem with the files from previous versions, but the last post I read about a release was beta 16.
Well, good to know it's out, anyway.
m@... I said nothing.
[Edit 2 times,
last edit by hal9000 at Nov 1, 2013, 1:03:39 AM]
Hans, About the crash you reported in version 4.2, could you check whether it happens with the installer version 4.1? I suspect you didn't encounter this bug before the release of version 4.2, because you were running the Beta with Java 7 and not with Java 6 as does the installer version.
Hi Emmanuel
I encounter a strange problem with the .dmg-version 4.2.: the render process stops after a few minutes and the "save" Button turns from inactive to active. It is even possible to save the uncompleted photo. But no error message appears. What could be wrong?
m@ Do you think it's a regression? Could you reproduce this issue more than once? If yes, could you send me the faulty file?
For your information, I just released Linux installers tagged as version 4.2a which replace the ones of version 4.2 on SourceForge.net. It fixes an annoying regression that didn't restore correctly maximized windows under that system. Windows and Mac OS X installers are unchanged.
Thanks Hans for your report. At a moment, I feared an other issue on your side, but I'm happy to know that finally, it was the same issue as the one Denis reported.
