Re: I exported the scene made in the Sweet Home 3d in separate .obj but i have problem with the walls
Please provide some examples because it's difficult to understand differences of behavior if you don't show them. For your information, walls (lines starting by "s wall_") are cited in the OBJ file in the order they were added to home. If the vertices indices their faces refer to (lines starting by "f") don't appear in the same order for the same collection of walls, it could be due to the way Java 3D stores them.
The bounding box you mention at the end of your message represents the ground. From version 4.0, you'll be able to avoid generating this ground if needed.
[Edit 1 times,
last edit by Puybaret at Mar 14, 2013, 6:20:31 PM]
[Mar 14, 2013, 6:19:42 PM]
[Link]
