Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: I exported the scene made in the Sweet Home 3d in separate .obj but i have problem with the walls » » » » Post: Re: I exported the scene made in the Sweet Home 3d in separate .obj but i have problem with the walls |
Print at Sep 20, 2026, 1:13:45 AM |
| Posted by Puybaret at Mar 14, 2013, 6:19:42 PM |
Re: I exported the scene made in the Sweet Home 3d in separate .obj but i have problem with the walls Please provide some examples because it's difficult to understand differences of behavior if you don't show them. For your information, walls (lines starting by "s wall_") are cited in the OBJ file in the order they were added to home. If the vertices indices their faces refer to (lines starting by "f") don't appear in the same order for the same collection of walls, it could be due to the way Java 3D stores them. The bounding box you mention at the end of your message represents the ground. From version 4.0, you'll be able to avoid generating this ground if needed. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 1:13:45 AM |
