Graphic Card
what kind of graphic card would you recommend? I have an old piece ... NVIDIA GeForce GT 220 I guess, that´s the point, why is the rendering of 3D so slow.
Any tips, whats the minimum to get an optimal run.
Re: Graphic Card
Keep your money then. The graphics card isn't used at the two best quality levels.
Re: Graphic Card
Please read the FAQHow can I speed up the rendering process in photo and video creation panes?
Re: Graphic Card
Thank you very much.
"...install a 64 bits version of Java on your system, download the Jar executable version of Sweet Home 3D and execute the java -Xmx4096m -jar path\to\SweetHome3D-3.7.jar command for 4 GB... "
The first two steps are OK, the execution of the command should be done in the windows command line? (I did it, but not sure if something happend)
Re: Graphic Card
Yes, but you can launch it also with Run text field. Be sure to give the real path to SweetHome3D-3.7.jar (you can drag and drop the file in the command line window to reproduce its path).
