Total posts in this thread: 8
Previous Thread This topic has been viewed 3998 times and has 7 replies Next Thread
Clovis
Video renderin speed low
I tere
First my keyboar is defective I do not ave two letters workin .
I bout a new computer to render fast my videos on Sweetome3d, bot te speed stills low.
I ave a ood macine now
Its a I7 2600K, wit 8B of ram
And te videos stills take only a litle bit less tan my previous macine, wit was realy slow (core 2 Duo 1.6 wit 2B o mem.)
Te instalation is new, clean, only W7 64, firefox and java
Wat can be wron wit it?
Tks
Clovis
[Dec 17, 2011, 2:12:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Video renderin speed low
What quality level do you use?
[Dec 17, 2011, 2:23:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Clovis
Te quality is te same on te two atempts, te second macine sowld be very faster, but its not.
Clovis
[Dec 17, 2011, 4:11:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
What is your file size?
How many light sources does your design have?
Do you have trees or plants in your design?
[Dec 17, 2011, 4:16:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
In the photo creation dialog, what quality do you use? 1, 2, 3 or 4?
[Dec 17, 2011, 6:26:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Clovis
I'm triin to do a ood quality video. I know it will take a lon. Te question is
Wy te new macine is not too faster ten te old one, its a realy ood macine, asnd I bout it for tat, to mke te animation faster tan te old one.
Te film is 50s lon, wit 1300 frames, quality is 4 and tere is about 12 lit spots onte cealin.
te size is 320x240 25 frames.
I updatyed te java foa a 64 v ersion and stills slow
Clovis
[Dec 18, 2011, 12:34:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Clovis,
If you want, send me your file, and I will make a test render.
[Dec 18, 2011, 9:14:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Clovis,
Before doing a test render on your file, I made a few changes. I decreased the number of lights from 11 to 6, because that would speed up rendering, while still allowing enough light.
I did the render on a computer with two cores running Ubuntu 11.10, and 2GB of RAM allotted to SH3D. No other processes were running that consumed a lot of computer time.
Check this paragraph in the FAQ to learn how you can allot more memory to SH3D.
How can I adjust the memory used by Sweet Home 3D?
The initial estimate of SH3D was that the rendering would take +/- 1h30m; the actual rendering took +/- 1h40m.
The settings were as I found in your file: Q3 at 320x240 pixels at 25 frames.
My guess would be that a rendering at Q4 would take probably 4x as much time.
My guess is that a machine with 4 processor cores should do the render in approximately half the time of my machine.
You may want to check that
- your computer uses all 4 cores
- you don't have a program running at the same time that uses a lot of processor time.
I have sent the modified file and the movie to your email.
[Dec 19, 2011, 8:47:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
