Total posts in this thread: 6
Previous Thread This topic has been viewed 4465 times and has 5 replies Next Thread
kenpeel
Can I change the shading or colour of a wall in plan view
I would like to be able to have different wall shading or colour in plan view to show different types of wall construction ... is this possible?
Thanks
Ken
[Apr 1, 2011, 10:46:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can I change the shading or colour of a wall in plan view
In plan view, you can just change the pattern of the walls with preferences dialog.
If you change the color of wall sides, you'll see the difference only in the 3D view.
[Apr 1, 2011, 10:50:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kenpeel
Thanks but I don't want to change the shading of all walls, just some of them.
[Apr 1, 2011, 10:58:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jorgesomers
I´d like to have a diferent pattern in plan which must represent 25 cm of wall.
Because I´m using a different type o brick which cannot be cut and all walls must be the size of multiple of 25 or 12,5 cm ..
If I had this "pattern" I can also visualy calculte other thing in the plan, like the place to fill with concrete etc..
If you need I can send you the icon I have the file in vector format.
[Mar 25, 2016, 11:57:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jorgesomers, it has been possible to set a different pattern on each wall since the version 4.0 released in 2013!
[Mar 26, 2016, 12:04:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jorgesomers
yes I know but I want my own pattern which will look like this brick
http://www.alroma.com.br/img/img-tijolo-02-g.jpg
and I want this kind of result using sweethome3d
http://www.alroma.com.br/pdf/exemplo_modulado03.pdf
[Mar 26, 2016, 2:36:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
