Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can I change the shading or colour of a wall in plan view |
| Print at Sep 6, 2026, 8:35:32 AM | View all posts in this thread on one page |
| Posted by kenpeel at Apr 1, 2011, 10:46:03 PM |
Can I change the shading or colour of a wall in plan view Hi, I would like to be able to have different wall shading or colour in plan view to show different types of wall construction ... is this possible? Thanks Ken |
| Posted by Puybaret at Apr 1, 2011, 10:50:46 PM |
Re: Can I change the shading or colour of a wall in plan view In plan view, you can just change the pattern of the walls with preferences dialog. If you change the color of wall sides, you'll see the difference only in the 3D view. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kenpeel at Apr 1, 2011, 10:58:38 PM |
Re: Can I change the shading or colour of a wall in plan view Thanks but I don't want to change the shading of all walls, just some of them. |
| Posted by jorgesomers at Mar 25, 2016, 11:57:11 AM |
Re: Can I change the shading or colour of a wall in plan view I´d like to have a diferent pattern in plan which must represent 25 cm of wall. Because I´m using a different type o brick which cannot be cut and all walls must be the size of multiple of 25 or 12,5 cm .. If I had this "pattern" I can also visualy calculte other thing in the plan, like the place to fill with concrete etc.. If you need I can send you the icon I have the file in vector format. |
| Posted by Puybaret at Mar 26, 2016, 12:04:35 PM |
Re: Can I change the shading or colour of a wall in plan view jorgesomers, it has been possible to set a different pattern on each wall since the version 4.0 released in 2013! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jorgesomers at Mar 26, 2016, 2:36:32 PM |
Re: Can I change the shading or colour of a wall in plan view yes I know but I want my own pattern which will look like this brick http://www.alroma.com.br/img/img-tijolo-02-g.jpg and I want this kind of result using sweethome3d http://www.alroma.com.br/pdf/exemplo_modulado03.pdf |
Current timezone is GMT Sep 6, 2026, 8:35:32 AM |
