Total posts in this thread: 4
Previous Thread This topic has been viewed 5213 times and has 3 replies Next Thread
Re: Transparent (glass) furniture??
Some time ago I found out that there are some transparant material names. WIthout using the D-option, these are transparant. I use them when building all kinds of structures. The nice part is that you can change the colour of the object, but the transparant material will not change colour. So you can make a window, and give it any colour you want, without the glass becoming the same colour, or losing its transparency.
I uploaded the files so you can download them if you like. Here are the direct links:
ftp://[email protected]/hansdirkse.n...Box_transp_ambertrans.obj
ftp://[email protected]/hansdirkse.n...e/Box_transp_bluetint.obj
ftp://[email protected]/hansdirkse.n...me/Box_transp_emerald.obj
ftp://[email protected]/hansdirkse.net/sweethome/Box_transp_flesh.obj
ftp://[email protected]/hansdirkse.net/sweethome/Box_transp_glass.obj
ftp://[email protected]/hansdirkse.n...x_transp_glassblutint.obj
ftp://[email protected]/hansdirkse.net/sweethome/Box_transp_meh.obj
ftp://[email protected]/hansdirkse.net/sweethome/Box_transp_plasma.obj
ftp://[email protected]/hansdirkse.net/sweethome/Box_transp_ruby.obj
ftp://[email protected]/hansdirkse.n...e/Box_transp_sapphire.obj
Good luck!
[Note from moderator: splited Transparent (glass) furniture?? thread]
[Edit 1 times, last edit by Puybaret at Mar 14, 2011, 6:23:24 PM]
[Dec 21, 2009, 11:52:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Oh dear, oh dear, I'm so clumsy. Here are the correct links to the files.
I hope it works, if not, give a shout :-)
Attachment Box_transp_ambertrans.obj (940 bytes) (Download count: 3572)
Attachment Box_transp_bluetint.obj (937 bytes) (Download count: 2918)
Attachment Box_transp_emerald.obj (936 bytes) (Download count: 2134)
Attachment Box_transp_flesh.obj (945 bytes) (Download count: 1985)
Attachment Box_transp_glass.obj (945 bytes) (Download count: 14352)
Attachment Box_transp_glassblutint.obj (941 bytes) (Download count: 3213)
Attachment Box_transp_meh.obj (932 bytes) (Download count: 1845)
Attachment Box_transp_plasma.obj (935 bytes) (Download count: 2184)
Attachment Box_transp_ruby.obj (933 bytes) (Download count: 1780)
Attachment Box_transp_sapphire.obj (937 bytes) (Download count: 1959)
Attachment Box_transp_shadow.obj (937 bytes) (Download count: 2363)
[Edit 1 times, last edit by hansmex at Dec 21, 2009, 6:10:20 PM]
[Dec 21, 2009, 12:41:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
socrate_54
Bonjour,
je sui novice en blender et j'essaye de créer une fenêtre en (.obj)
la forme est bonne mais seul le "ltbrown" est appliqué.
voici une extraction du fichier .obj
# Blender3D v249 OBJ File: GGL1.blend
# www.blender3d.org
mtllib GGL1.mtl
v 3.070711 2.010710 -2.150000
v 3.092388 1.978268 -2.150000
vn 0.831470 0.555570 0.000000
vn 0.831471 0.555569 0.000001
usemtl mintgrn
s off
f 33//1 1//1 2//1
f 34//2 18//2 17//2
v 3.499998 2.539997 -3.050000
v 3.500000 2.539995 -2.150000
v 3.499996 -6.460001 -2.150000
vn 1.000000 0.000000 -0.000002
vn 1.000000 -0.000000 0.000003
usemtl ltbrown
s off
f 89//35 92//35 88//35
v 3.099998 1.339998 -2.650000
v 3.099998 -6.059999 -2.650000
v -3.099999 -6.059998 -2.650000
vn 1.000000 0.000000 -0.000014
vn 1.000000 -0.000000 0.000021
usemtl glasstransparent
s off
f 97//47 93//47 96//47
Le résultat est le même si les divisions "v" sont précédées de g box1 g box1.1 g carreau
Avec un carreau seul cela fonctionne la transparence est bonne.
Testé sous windows XP et ubuntu 11.04 le résultat est le même.
sweet home 3D 3.3
blender 2.49
existe t il un utilisateur moins novice qui puisse m'aider?
Cordialement.
[Aug 7, 2011, 4:24:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
socrate_54
Bonjour,
j'ai trouvé pourquoi les transparences ne fonctionnaient pas.
dans le fichier .mtl était redéfini "newmtl glasstransparent"
en enlevant cette section voici le résultat.
Le mur est même découpé par cette fenêtre inclinée.
Merci aux développeurs de SH3D. Ce logiciel permet de visualiser avant de construire réellement.
Cordialement
[Aug 10, 2011, 1:34:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
