error message on exporting to SH3F
Emmanuel,
While trying to export all furniture an error message appeared I haven't seen before. This happened in both v2.6 and v3.0. Do you know what went wrong?
Re: error message on exporting to SH3F
Hans, There must be a 3D model of an imported piece of furniture that is wrong. - Stop Sweet Home 3D, - Open .eteks/sweethome3d/preferences.xml in your home directory with any text editor, - Search the line that contains Content315000321816400142.pref, - In that line note the number after the "furnitureModel#" text, - Find the line that contains "furnitureName#" followed by the same number, and note down the name of the piece of furniture that caused the problem, - Close the text editor and send me /home/hans/eteks/sweethome3d/Content315000321816400142.pref if possible so I can test where the problem comes from, - Open Sweet Home 3D and delete the piece of furniture you found from the catalog.
Emmanuel,
Thank you for your reply. This is what I found:
Content315000321816400142.pref points to <entry key="furnitureModel#39 ">jar:file:Content315000321816400142.pref!/models/Composant%235 .dae</entry>
points to <entry key="furnitureName#39 ">bed, red #5</entry> or did you mean <entry key="furnitureName#235 ">Light Cube Two</entry>
When inspecting the models, I could see it's the second one, which I already have deleted. It was an experiment in transparency. Still, if it interests you, the pref file is attached.
[Edit 1 times,
last edit by hansmex at Nov 23, 2010, 12:39:55 AM]
