Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: error message on exporting to SH3F |
| Print at Oct 1, 2026, 1:38:55 AM | View all posts in this thread on one page |
| Posted by hansmex at Nov 23, 2010, 12:18:28 AM |
error message on exporting to SH3F Emmanuel, While trying to export all furniture an error message appeared I haven't seen before. This happened in both v2.6 and v3.0. Do you know what went wrong? Hans ![]() ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Nov 23, 2010, 1:20:17 AM |
Re: error message on exporting to SH3F Hans, There must be a 3D model of an imported piece of furniture that is wrong. - Stop Sweet Home 3D, - Open .eteks/sweethome3d/preferences.xml in your home directory with any text editor, - Search the line that contains Content315000321816400142.pref, - In that line note the number after the "furnitureModel#" text, - Find the line that contains "furnitureName#" followed by the same number, and note down the name of the piece of furniture that caused the problem, - Close the text editor and send me /home/hans/eteks/sweethome3d/Content315000321816400142.pref if possible so I can test where the problem comes from, - Open Sweet Home 3D and delete the piece of furniture you found from the catalog. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Nov 23, 2010, 1:39:41 AM |
Re: error message on exporting to SH3F Emmanuel, Thank you for your reply. This is what I found: Content315000321816400142.pref points to <entry key="furnitureModel#39 ">jar:file:Content315000321816400142.pref!/models/Composant%235 .dae</entry> points to <entry key="furnitureName#39 ">bed, red #5</entry> or did you mean <entry key="furnitureName#235 ">Light Cube Two</entry> When inspecting the models, I could see it's the second one, which I already have deleted. It was an experiment in transparency. Still, if it interests you, the pref file is attached. Hans ---------------------------------------- ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Nov 23, 2010, 1:59:18 AM |
Re: error message on exporting to SH3F I meant furnitureName#39 therefore "bed, red #5" ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Nov 23, 2010, 10:12:01 AM |
Re: error message on exporting to SH3F Emmanuel, Thanks once again. I deleted the bed as well. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Oct 1, 2026, 1:38:55 AM |
