Romania
Re: Furniture Library Editor 2.2
Maybe this tread could help. Anyway, I've stop many years ago to use the system provided java or sh3d related. I, under linux, use only installer version to avoid head-pain.
Germany
The solution from Emmanuel is working on my system.
MSI GP60, Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy, SH3D 7.5 with Photo-video rendering 2.8
Germany, Berlin
Congrats! For me it doesn't.
What helped was a different graphics driver for my outdated nvidia. I changed the Linux driver from proprietary to open source nouveau this afternoon, after even SH3D itself crashed my graphics. FLE has been running since then.
Cheers - Joe //
Germany
I have an older laptop with a GT 740M GPU and Driver 470.256.02.
X Server version 11.0, Vendor version 1.21.1.4 and NV-Control 1.29.
And only 1 screen attached.
Germany, Berlin
Interesting! I'm also using the 470 generation. Since my driver change to nouveau, my 2nd Monitor has been ignored, and so has the HDMI audio output. Even after I switched back to proprietary drivers - which in turn did not crash neither SH3D nor FLE anymore.
Anybody got a left-over, maybe outdated, non-nvidia PCIe graphics card for fair money? All I want is to drive one 3840×2160 and one 1920×1080 display, no gaming, even fine @ 30 Hz. PMs welcome.
Cheers - Joe //
Hey there, I’m pretty new to Sweet Home 3D, I have a problem trying to start the Furniture Library Editor and I was hoping I could get some help with that here? I’m running Windows 10 Pro, I’ve installed the Java Development Kit 23.0.1 (64 bit), but that just seems to be a collection of weblinks. I installed Java Version 8 Update 431, (Build 1.8.0_431-b10), and I’ve downloaded Furniture Library Editor 2.2, but when I double click on it, nothing happens. No menus open, nada. I’ve read this whole thread, but I’m at a bit of a loss, as I’m not a programmer and have never done anything with Java before. I need to get the furniture editor up and running as I’m working on a project with custom lights, and so I need to do some editing. I’m also totally new to 3D modelling, but I’ve been teaching myself what I can so far, and others here have been really kind and helpful in offering explanations as well. Can anyone please help me out with this?
usa
Problem: warning messages from Java jdk-24
I'm a irst time (attempted) user of the library creation tool under windows 10.
I installed and configured Java jdk-24, which seems to work.
1. How can I display the current documentation for the furniture library creation tool?
2. invoking the command
+ java -jar ./FurnitureLibraryEditor-2.2.jar opens the editor window.
However, when I tried to drag-and-drop of the directory folder containing the .obj and .mtl files into the main pane of that window, nothing happens but I get this error message in the cli (I'm using cygwin bash) command window:
WARNING: A restricted method in java.lang.System has been called WARNING: java.lang.System::loadLibrary has been called by com.jogamp.common.jvm.JNILibLoaderBase in an unnamed module (file:/C:/User s/selden/Documents/sh3d_models/FurnitureLibraryEditor-2.2.jar) WARNING: Use --enable-native-access=ALL-UNNAMED to avoid a warning for callers in this module WARNING: Restricted methods will be blocked in a future release unless native access is enabled
Hopefully this problem can be fixed in the next release of the Furniture Library Editor. In the meantime, I'll try what java suggests.
Selden
... However, when I tried to drag-and-drop of the directory folder containing the .obj and .mtl files into the main pane of that window, nothing happens but I get this error message in the cli (I'm using cygwin bash) command window:
You can't drag a folder in the Furniture Library Editor. You can select multiple OBJ files and/or ZIP files containing OBJ/MTL files and drag&drop those in the FLE window.
I use the Java runtime provided with Sweet Home 3D and that one works perfectly fine. Correction, for the FLE is use an older runtime: 1.7.0_261.
[Edit 1 times,
last edit by Keet at Jun 9, 2025, 9:04:01 PM]
Sverige
I finally got the library to open on my old windows 7 but when I try to create a new library I only got one funiture , when I import another it only changes the first one to the new object, I’ve tried the import button and drag and drop ( I can see the import process ) what is I doing wrong?
