Last version is currently 2.0, available here and is still a JAR executable file requiring that you install Java or that you reuse the java executable bundled with Sweet Home 3D installer.
US
Re: Furniture Library Editor 2.0
Thank you for the update.
After edits are made I save to new file. Delete program files from user. Install the new sh3f file.
*** Shows multiple folders (categories) with my files, although I have saved them as only one category. Names are not changing. (oven, oven = oven 1, oven 2) ***
Is this a bug or are files somehow marked not to move from category?
Found a little glitch: The column Model Size doesn't order according to the model sizes.
Thanks for reporting this issue. It will be fixed in the next release.
United States
Downloaded the latest version and seem to be having a problem when trying to load my library. Going back to version 1.28, I'm having the same problem, so it may have something to do with Java. When I click Open Library, the load dialog is very slow and I can't change directories. If I click on Import Furniture, no dialog box comes up at all. I ran the program from the console and generated the following log file:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: Comparison method violates its general contract! at java.util.ComparableTimSort.mergeHi(Unknown Source) at java.util.ComparableTimSort.mergeAt(Unknown Source) at java.util.ComparableTimSort.mergeCollapse(Unknown Source) at java.util.ComparableTimSort.sort(Unknown Source) at java.util.Arrays.sort(Unknown Source) at sun.awt.shell.Win32ShellFolderManager2.get(Unknown Source) at sun.awt.shell.ShellFolder.get(Unknown Source) at com.sun.java.swing.plaf.windows.WindowsFileChooserUI$DirectoryComboBoxModel.addItem(Unknown Source) at com.sun.java.swing.plaf.windows.WindowsFileChooserUI$DirectoryComboBoxModel.access$800(Unknown Source) at com.sun.java.swing.plaf.windows.WindowsFileChooserUI.doDirectoryChanged(Unknown Source) at com.sun.java.swing.plaf.windows.WindowsFileChooserUI.access$1100(Unknown Source) at com.sun.java.swing.plaf.windows.WindowsFileChooserUI$11.propertyChange(Unknown Source) at java.beans.PropertyChangeSupport.fire(Unknown Source) at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source) at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source) at java.awt.Component.firePropertyChange(Unknown Source) at javax.swing.JFileChooser.setCurrentDirectory(Unknown Source) at sun.swing.WindowsPlacesBar.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.JToggleButton$ToggleButtonModel.setPressed(Unknown Source) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$500(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue$4.run(Unknown Source) at java.awt.EventQueue$4.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.WaitDispatchSupport$2.run(Unknown Source) at java.awt.WaitDispatchSupport$4.run(Unknown Source) at java.awt.WaitDispatchSupport$4.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(Unknown Source) at java.awt.Dialog.show(Unknown Source) at javax.swing.JFileChooser.showDialog(Unknown Source) at javax.swing.JFileChooser.showOpenDialog(Unknown Source) at com.eteks.sweethome3d.swing.FileContentManager.showFileChooser(Unknown Source) at com.eteks.sweethome3d.swing.FileContentManager.showOpenDialog(Unknown Source) at com.eteks.furniturelibraryeditor.FurnitureLibraryEditor$1.showOpenDialog(Unknown Source) at com.eteks.furniturelibraryeditor.viewcontroller.EditorController$2.run(Unknown Source) at com.eteks.furniturelibraryeditor.viewcontroller.EditorController.open(Unknown Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(Unknown Source) at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source) at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source) at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$500(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue$4.run(Unknown Source) at java.awt.EventQueue$4.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)
This must be due to a bug in Java, but it should be fixed in the coming version of the editor. Meanwhile you should run the editor from the command line to define the java.util.Arrays.useLegacyMergeSort to true, with a command of the form:
Since you can't add a custom property that is preserved when you save the file in the library editor I wondered if there are other properties that are supported?
Second question: How do you remove a planicon other than manually editing the properties file and removing the image from the .sh3f zip?
No it's the only supported properties for a library. Custom properties are for pieces of furniture, not the library itself.
Sorry, there's no other way for the moment. I simply didn't think about it when I programed this feature.
Would it be possible to have the Furniture Libary Editor generate a new catalog icon when you rotate the preview icon in the modify dialog? Every property is correctly saved except a change in the perspective of the preview icon.
I know I can set a custom icon but that seems a little overkill. In most cases a simple replace with the preview that is shown is sufficient (unless of course a custom icon is set).
