Print at Sep 13, 2026, 8:33:49 AM
Posted by selden at Jun 9, 2025, 8:29:18 PM
Problem: warning messages from Java jdk-24
I'm a irst time (attempted) user of the library creation tool under windows 10.
I installed and configured Java jdk-24, which seems to work.
1. How can I display the current documentation for the furniture library creation tool?
2. invoking the command
+ java -jar ./FurnitureLibraryEditor-2.2.jar
opens the editor window.
However, when I tried to drag-and-drop of the directory folder containing the .obj and .mtl files into the main pane of that window, nothing happens but I get this error message in the cli (I'm using cygwin bash) command window:
WARNING: A restricted method in java.lang.System has been called
WARNING: java.lang.System::loadLibrary has been called by com.jogamp.common.jvm.JNILibLoaderBase in an unnamed module (file:/C:/User
s/selden/Documents/sh3d_models/FurnitureLibraryEditor-2.2.jar)
WARNING: Use --enable-native-access=ALL-UNNAMED to avoid a warning for callers in this module
WARNING: Restricted methods will be blocked in a future release unless native access is enabled
Hopefully this problem can be fixed in the next release of the Furniture Library Editor. In the meantime, I'll try what java suggests.
Selden
