Previous Thread This topic has been viewed 1701 times and has 2 replies Next Thread
jz77f
How to move Furniture catalog view, etc., back
This has happened to me after a Manjaro Linux update. The four panes/views are positioned differently what they used to be. What was at the top is at the bottom, what was on the left is on the right. I've tried and reinstalled SweetHome3D but it didn't help. Note the same version which I downloaded from the SweetHome3D site and run as a script from terminal is fine.
[Jul 5, 2026, 11:02:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to move Furniture catalog view, etc., back
This is most likely caused by the used JAVA version. The version shipped with Sweet Home 3D works fine and some higher versions too. The version you are using seems to cause problems.
I use 1.8.0_471 and that one works as it should, including the plugins that require this higher version against the one that is shipped with Sweet Home 3D.
Just download that version and extract it in place of the current Sweet Home 3D lib/bin directories.
[Jul 5, 2026, 11:45:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
spaigroa70
It also seems worth mentioning the exact Java version that causes the issue, as that could help others avoid spending time reinstalling Sweet Home 3D.
fnf
[Jul 10, 2026, 5:16:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
