How to move Furniture catalog view, etc., back
This has happened to me after a Manjaro Linux update. The four panes/views are positioned differently what they used to be. What was at the top is at the bottom, what was on the left is on the right. I've tried and reinstalled SweetHome3D but it didn't help. Note the same version which I downloaded from the SweetHome3D site and run as a script from terminal is fine.
Re: How to move Furniture catalog view, etc., back
This is most likely caused by the used JAVA version. The version shipped with Sweet Home 3D works fine and some higher versions too. The version you are using seems to cause problems. I use 1.8.0_471 and that one works as it should, including the plugins that require this higher version against the one that is shipped with Sweet Home 3D. Just download that version and extract it in place of the current Sweet Home 3D lib/bin directories.
