Previous Thread This topic has been viewed 3306 times and has 2 replies Next Thread
Fred19732
sad How to rotate a whole map from vertical to horizontal
Hi everybody,
I built a house plan in a vertical position.
My question is : how can I do to rotate the whole map from vertical to horizontal without having to rotate each object of the map?
many thanks for your answers
[Jan 22, 2025, 10:47:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
Re: How to rotate a whole map from vertical to horizontal
Select all the objects, then group them. Now you can rotate everything in the group at once.
[Jan 22, 2025, 8:53:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Unfortunately not all object types can be grouped. Luckily there are 2 plugins that can do this work:
- Advanced plan editing plugin
- Home rotator plugin
I encourage to try both of them, the first is more complete, but the second should be a lot easier to use for your use case.
[Jan 24, 2025, 8:56:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
