Print at Aug 21, 2026, 1:47:10 AM View all posts in this thread on one page
Posted by Fred19732 at Jan 22, 2025, 10:47:44 AM
sad   How to rotate a whole map from vertical to horizontal
Hi everybody,
I built a house plan in a vertical position.
My question is : how can I do to rotate the whole map from vertical to horizontal without having to rotate each object of the map?
many thanks for your answers
Posted by MarioSambol at Jan 22, 2025, 8:53:56 PM
Re: How to rotate a whole map from vertical to horizontal
Select all the objects, then group them. Now you can rotate everything in the group at once.
Posted by Daniels118 at Jan 24, 2025, 8:56:00 PM
Unfortunately not all object types can be grouped. Luckily there are 2 plugins that can do this work:
- Advanced plan editing plugin
- Home rotator plugin
I encourage to try both of them, the first is more complete, but the second should be a lot easier to use for your use case.
