Romania
Re: Sweet Home 3D 7.2
If it were only that simple
You and Emmanuel have wright. I've tried to find a general formula but I've fail (until now). A possibly workaround could be to have a specific prefix for fixed part (only one) on every adjustable model prefixed with sweethome3d_fixed_[part-name] like sweethome3d_fixed_exterior-frame which could be used as references for YXZ. I could also to add another custom property to roof windows and, to plugin, a deformation listener but this will produce a significant slowing of the entire program. So, at that moment, I will let it as is. With/Without this I'm wait the final 7.2 release to enjoy discovering the news
Hello,
Here's the last beta of Sweet Home 3D 7.2 (I hope).
It provides last translations (thanks YGYL) and improvements in the 3D view handling. Moved objects should now better follow the mouse cursor along the horizontal axis, and I also added the ability to rotate the selected piece of furniture in the 3D view when you press Ctrl + Shift keys before pressing the mouse button to rotate it (alt / option + shift under macOS). Thanks for your tests.
[Edit 1 times,
last edit by Puybaret at Sep 22, 2023, 8:06:13 PM]
No need for that. If a part doesn't have a deformation string it should stay where it is, 'simple' as that. Only the deformation parts should move.
Here's the last beta of Sweet Home 3D 7.2 (I hope):
I'm going to try it. The previous beta worked quite nicely as well.
Italy
For anyone who is not whatching the dedicated thread, I inform you that I've just released the version 4.0 of Pan 3D View plugin which is compatible with SweetHome3D 7.2. If you use Wirings and/or 3D dimension lines plugins, please update these too to the latest release available.
A note about 3D dimension lines: since SH3D now supports vertical dimension lines, the plugin is no longer required for most cases, however it is still useful to draw dimension lines with generic orientation in space.
As Keet noted here, I was able to add a new property to my library lights to replace the use of the Description property which can be changed by the user.
By using the system property com.eteks.sweethome3d.additionalFurnitureProperties in a configuration file for the installer or as a JAR executable parameter, it is possible to display the new property column without it being editable because in this case the Other properties button does not appear.
As for the management of this new property by the rendering plug-in, simply retrieve the object property from its name and test the values.
EnkoNyito
