Previous Thread This topic has been viewed 340586 times and has 90 replies Next Thread
Re: Sweet Home 3D 7.2
Great, I was already using the Description field to show the originating library (in bold) in the catalog tooltip. Without your change that would have interfered if I did that with your library.
[Sep 26, 2023, 10:39:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@Keet
The Description field is accessible and editable for users since SH3D-7.1.
For variable lights (automatic or daylight), there was a risk of interfering with the management of the rendering plug-in.
Even if I had no feedback in this direction, I preferred to "secure" this management by updating the library with the new option proposed by SH3D-7.2.
According to my tests, several additional properties can have the same name because their identifier is different when they are created.
EnkoNyito
[Sep 27, 2023, 10:41:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yes, the Description field was already available in 7.1., I've been using it since it first became available through the Furniture Library Editor. Until the new features in 7.2. you had no other choice than to use some field to store the data for you lights. Although it worked it was a solution out of necessity, one I as a developer try to avoid whenever possible. You seem to be of the same opinion since you made the effort to make it right.
Most users will not realize how powerful this new addition to Sweet Home 3D is since it will mostly be used by plug-in developers. They now have to tools to add custom properties with a meaningful name and have control over them within their plug-ins. It gave you the option to create lights with custom properties not available in Sweet Home 3D.
Great work and excellent use of the new custom properties! As far as I know you are the first one to use these custom properties in furniture available for Sweet Home 3D.
[Sep 28, 2023, 9:52:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
INABCinema
US
Thank you so much for the 3D viewable measurements! This is something I have wished for years.
I do have one additional wish, can the measurements have an end point elevation so we can do sloped (angled) measurements?
Once again, thank you so much for this great feature.
[Oct 17, 2023, 6:16:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
@INABCinema
You can do it using the 3D dimension lines plugin:
https://www.sweethome3d.com/support/forum/viewthread_thread,11543#53739
[Oct 18, 2023, 8:17:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
vl4d
I have found minor problem
In the furniture list order by level does not actually work
(yes, i'm not using sweet home 3d for completely different use then it is meant to be used, but I kinda at least know how to use this sw)
[Oct 29, 2023, 7:26:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Do you use levels at the same elevation? I see that the procedure which compares levels for sorting furniture might need some refinement because it doesn’t take into account level index at the same elevation.
[Oct 30, 2023, 9:03:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Wouldn't the best way to sort levels be elevation+levelname? That would sort the levels from lowest to highest level and sort the levels at the same elevation by their name.
Alternatively the levels could be sorted using the order of the level tabs which would nicely follow the order the user organized his levels.
[Oct 30, 2023, 1:52:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
If we're collecting votes, then definitely use the ordering of the tabs.
I was always of the opinion that the levels could be integrated into the furniture list as a single tree anyway. My model has a lot of levels and ends up over 4 rows of tabs. It eats important vertical space and is irritating from a usability point of view as the rows jump around when clicked. It would also make finding a particular levels furniture in the list much easier.
[Oct 30, 2023, 4:20:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
vl4d
Yes I do use levels at the same elevation.
It is very minor issue, i do export it to csv and work with that, but for me verifying if I have all items i need to order (pipes, fittings, valves, ...) it is easier to just go trough the "level" and list of items directly in the sweet home 3d as it highlights me what the items in on the plan.
[Oct 30, 2023, 11:54:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
