Re: Sweet Home 3D 7.2
I think what dorin wants to express is that an object doesn't remain in it's (vertical/Z) position when a deformation changes it's height. So no problem with the door because it stays the same height but the elevation of the velux window changes when opened. The non-deforming part of the window should remain at it's original position. From what I can see on the images the deformed furniture has it's bottom at the same elevation as the non-deformed was, which is not correct.
Romania
@Keet You have partially right.
Indeed but at different X and Y. If you look closely to my first two picture you could see I've arranged the doors at same Y and the corresponding X. After I open the door (Thanks God wasn't a Window ) the bounding box has been modified and of course the X and Y BUT, somewhere in the code Emmanuel compute the necessarily corrections so the door frame appear to stay in their position and only the door has been moved. I need this correction to be made also for Z. I've tried to find the responsible part of code but maybe I've don't try hard enough.
Today, the Beta 8 updates the help in English and French and translations in almost languages (see updated links in the first post of this thread).
Traditional and Simplified Chinese translations are still missing. If anybody want to help, Chinese speaking users would surely appreciate your contribution.
German contributors weren't available this time too, therefore I translated the new words myself and with the help of web translation tools, I hope the translation is quite accurate (I studied German during 5 years at school and that should help to avoid main grammar faults). I have mostly some doubts about how to present the list of postures. At the moment, I used verbs as shown in the following image but I'm not sure it's correct. What do you think?
Dorin, I was able to reproduce the issue you reported on double-hung windows but I don't find it's really a problem, since you obtain this error when you move a window part lower than the bottom of the window, a position which has no meaning.
How is this not a problem? I agree that a deformed object should elevate if the deformation would make the elevation of the new bounding box negative. This situation could be resolved by placing the furniture on a lower level and raise the elevation to its original elevation on the higher level, IF it worked correctly.
Take this example: A cabinet with a door with the hinge at the bottom. So the door folds down from vertical in front of the cabinet to vertical 'hanging' from the bottom of the cabinet. I've seen this type of furniture where the 'door' becomes a writing table but can also be lowered completely down. As long as the bottom of the opened 'hanging' door doesn't make the elevation of the new bounding box negative the cabinet itself should remain at it's position.
In short: If a deformation doesn't cause a negative elevation, the non-deformed part should remain at its position, including the vertical position.
By-the-way, this is not a specific 7.2 problem since the same happens in 7.1.
Romania
1. Correct, but what if it is a pocket window? 2. If you use a roof part with a window already inserted (from a wall) will be also no problem. 3. If you make a hole in the roof and insert manually a closed turn window (like in this post ) you will have problems with the elevation every time you open the window. Anyway in the future release of RG-4.5 the holes and windows are automatically created and inserted on the roof in the correct position but I can't avoid future window elevation modifications. My workaround was to mentioned this in the future user manual of RG. Probably I will need to elaborate a little the operation for users: new elevation = old elevation - (new High - old High)/2 or something similarly with more screenshots. As you can see there it is solutions for everything
If it were only that simple This is correct if the deformation extends both up and down with the same length. But take the example I gave in my previous post and the deformation goes 100% down. Same if you have an elevator escape hatch where the hatch door 'falls' down, so again 100% down. With the Velux window it could be 50/50 if the hinge is at the center of the rotating part AND at the center of the rest of the window, but even that is not always the case with this type of window. It's pretty difficult to determine what percentage extends up and down. After that the calculation to retain the elevation for the non-deformed part is trivial. It should be possible because similar calculations are done for left/right with doors and windows to keep the non-deforming part in place. The same can be used to retain the elevation.
Very willing to provide translations in Simplified Chinese. How exactly can I help you?
There's a nice Translation Guide that describes how you can create translations.
The translation guide is mostly useful to start a new translation. As I finally tried to update Chinese translation from words existing in Sweet Home 3D + some very cautious use of web translation tools, it's almost ready (except for posture names) and I mostly need YGYL to check if it's ok. May I write you directly?
