Total posts in this thread: 5
Previous Thread This topic has been viewed 5910 times and has 4 replies Next Thread
sasha82
Italia
Problem with PDF and texture
Good morning.
I recently changed computers and installed the latest version of SH3d.
16ram
NVidia GForce gtx 1650 4gb graphics card
The program works fine, no error messages.
The render creates them correctly even in high definition and quickly.
But when I try to add texture to the floors, the problems arise.
The texture is not seen in the 2d screen, however it can be seen perfectly in the 3d screen
Then when I create the PDF of the 2d plan the texture does not appear but it is all white.
I tried using both internal and external textures of the program. But it doesn't work either way.
I thought it was a PDF reader problem but it's not.
I have installed previous versions of SH3d but nothing.
Do I need to install any additional programs or change any settings?
Thanks for your help
[Feb 4, 2023, 10:08:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
Re: Problem with PDF and texture
Sounds like you need to change the option "Room rendering in plan:" setting in the Preferences from "Monochrome" to "Floor color or texture"
[Feb 4, 2023, 8:11:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sasha82
Italia
Thanks, where do I find this option to change?
[Feb 4, 2023, 8:42:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You could, of course, read the manual... But if that's not your thing, look in "Preferences".
[Feb 4, 2023, 10:46:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sasha82
Italia
Thank you! I solved the problem thanks to your suggestion!
[Feb 5, 2023, 6:51:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
