Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem with PDF and texture |
| Print at Sep 29, 2026, 7:22:01 AM | View all posts in this thread on one page |
| Posted by sasha82 at Feb 4, 2023, 10:08:28 AM |
Problem with PDF and texture Good morning. I recently changed computers and installed the latest version of SH3d. 16ram NVidia GForce gtx 1650 4gb graphics card The program works fine, no error messages. The render creates them correctly even in high definition and quickly. But when I try to add texture to the floors, the problems arise. The texture is not seen in the 2d screen, however it can be seen perfectly in the 3d screen Then when I create the PDF of the 2d plan the texture does not appear but it is all white. I tried using both internal and external textures of the program. But it doesn't work either way. I thought it was a PDF reader problem but it's not. I have installed previous versions of SH3d but nothing. Do I need to install any additional programs or change any settings? Thanks for your help |
| Posted by sjb007 at Feb 4, 2023, 8:11:29 PM |
Re: Problem with PDF and texture Sounds like you need to change the option "Room rendering in plan:" setting in the Preferences from "Monochrome" to "Floor color or texture" |
| Posted by sasha82 at Feb 4, 2023, 8:42:24 PM |
Re: Problem with PDF and texture Thanks, where do I find this option to change? |
| Posted by hansmex at Feb 4, 2023, 10:46:38 PM |
Re: Problem with PDF and texture You could, of course, read the manual... But if that's not your thing, look in "Preferences". H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by sasha82 at Feb 5, 2023, 6:51:10 PM |
Re: Problem with PDF and texture Thank you! I solved the problem thanks to your suggestion! |
Current timezone is GMT Sep 29, 2026, 7:22:01 AM |
