Re: Staircase generator plug-in
@el_dario Version 4.2 or later will be posted on sourceforge as soon as it's ready
---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
Why so difficult? You can easily calculate an SVG cutout string using the v lines in a room object (or any other object where an outline can be calculated from). It is much easier to draw a room then the screenshot copies. Here's the code for it in PHP and C#. Both code listings are made to to be readable by non-programmers too. This was a test for me so a little optimization is probably possible. The C# code is close to Java code so should be easy to convert. The PHP code is amateur work, I only use it for my websites.
C# code:
using System; using System.IO; using System.Collections; using System.Collections.Generic; using System.Text;
namespace SH3D { public class SVG { // constructor public SVG () {}
/// <summary> /// Create an SVG cutout string from the given obj file /// </summary> /// <returns> /// The SVG cutout string /// </returns> /// <param name='sourcefile'> /// The obj file to use for creating the SVG string. /// A cutout string is generated using the v lines in the first group, best result with a room object. /// </param> public string CreateSVGcutout (string sourcefile) { if (!File.Exists (sourcefile)) { return string.Empty; }
#region create vertice list // Create an empty list to hold all vertices (v lines) List<Vertice> vertices = new List<Vertice> ();
// Read all lines in the obj file into a string array String[] lines = File.ReadAllLines (sourcefile); bool start = false;
// For each line that starts with "v " create a Vertice object and add it to the vertices list. // z is set to 0 by default, not used for a SVG cutout. foreach (string line in lines) { if (line.StartsWith ("v ")) { start = true; string[] parts = line.Split (new char[] {' '}); // 0 = "v", 1=X, 2=Z, 3=Y Vertice v = new Vertice (double.Parse(parts [1]), double.Parse(parts [3]), 0.0d); vertices.Add (v); } else { // First set of v lines done, ignore the rest if (start) { break; } } } #endregion create vertice list
#region object bounderies // Get the object bounderies, I.E. the width and depth of the object // These are needed to calculate the L points // Calculating this enables processing objects that dont't have 0,0 as the position coordinates. double minwidth = 0.0; double maxwidth = 0.0; double mindepth = 0.0; double maxdepth = 0.0; bool first = true; foreach (Vertice v in vertices) { if (first) { minwidth = v.X; maxwidth = v.X; mindepth = v.Y; maxdepth = v.Y; first = false; } else { minwidth = Math.Min (minwidth, v.X); maxwidth = Math.Max (maxwidth, v.X); mindepth = Math.Min (mindepth, v.Y); maxdepth = Math.Max (maxdepth, v.Y); } }
// Recalculate the vertice points so they start from the correct origin for (int i=0; i< vertices.Count; i++) { vertices.X = vertices.X-minwidth; vertices.Y = vertices.Y-mindepth; } #endregion object bounderies
#region create SVG string string svg = ""; first = true; foreach (Vertice v in vertices) { if (first) { // first starts with "M" svg += "M" + Math.Round(v.X/width,4).ToString() + "," + Math.Round(v.Y/depth,4).ToString() + " "; first = false; } else { // add L points svg += "L" + Math.Round(v.X/width,4).ToString() + "," + Math.Round(v.Y/depth,4).ToString() + " "; } } svg += "z"; // z = back to start (M) #endregion create SVG string
// return the SVG string return svg; } } }
PHP code:
<?php include_once "base.php"; if (session_id() == "") { session_start(); }
class SVGCutout { // private $_exportpath = TMPPATH; public $lines;
// get the object bounderies, I.E. the width and depth of the object // these are needed to calculate the L points $minw = 0.0; $maxw = 0.0; $mind = 0.0; $maxd = 0.0; $first = true;
An excellent solution. Thank You However in many cases I need to get creative and design a cutout which does not correspond to model edges. e.g. circular for a T shaped
That's why this code solution is easier. You can draw a room in any form you need, for example a star or T and it will calculate the cutout. To be clear: this is independent from the staircase object, completely separate. It is as if you draw the outline as in your examples but now without screenshots and as a room object.
Hi, thanks for this nice plugin! Could you maybe add a function to make the "first stairs count" asymmetric, i.e. different counts for the bottom treads and the top treads?
So basically add also a "last stairs count" or something? Or maybe better names are "lower tread count" and "upper tread count"?
I have a staircase where this is like that.
Also, the latest version 4.2 is not detected by the Plugin Manager plugin yet!
Romania
Maybe this could help you.
