Re: Octagon
1 - Click the walls icon 2 - Click on any point in the 2D window 3 - Hit ENTER 4 - Enter 0,0 as X,Y coordinates (or any other starting point you want, use TAB in between) 5 - Hit ENTER and the wall will stretch horizontally to the right from the starting coordinate 6 - Overwrite the suggested wall length 7 - Hit TAB and enter 135 degrees as angle 8 - Overwrite wall thickness if necessary 9 - hit ENTER 10 - repeat steps 5-9 seven times, SH3D will suggest the same wall length, change angle to 135 degrees - you will note that using TAB is enough to go to wall angle, then ENTER is enough to complete each step) 11 - after 7th repetition octagon is ready, on ENTER the last wall segment will join the first segment
(PS - I tried it twice after reading my text, it should work as described)
[Sep 14, 2021, 5:33:47 PM]
[Link]
