Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Octagon » » » » Post: Re: Octagon |
Print at Sep 26, 2026, 6:29:09 PM |
| Posted by hansmex at Sep 14, 2021, 5:33:47 PM |
Re: Octagon 1 - Click the walls icon 2 - Click on any point in the 2D window 3 - Hit ENTER 4 - Enter 0,0 as X,Y coordinates (or any other starting point you want, use TAB in between) 5 - Hit ENTER and the wall will stretch horizontally to the right from the starting coordinate 6 - Overwrite the suggested wall length 7 - Hit TAB and enter 135 degrees as angle 8 - Overwrite wall thickness if necessary 9 - hit ENTER 10 - repeat steps 5-9 seven times, SH3D will suggest the same wall length, change angle to 135 degrees - you will note that using TAB is enough to go to wall angle, then ENTER is enough to complete each step) 11 - after 7th repetition octagon is ready, on ENTER the last wall segment will join the first segment (PS - I tried it twice after reading my text, it should work as described) H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 26, 2026, 6:29:09 PM |
