Total posts in this thread: 7
Previous Thread This topic has been viewed 6873 times and has 6 replies Next Thread
LizardQueen
United States
smile Glass wall
Is there a way to make a glass wall? I am trying to make a conservatory/greenhouse.
[Aug 23, 2021, 8:37:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
reddy.shyam
Re: Glass wall
Take a glass window object and modify to take make the borders invisible. That should do I believe.
[Aug 23, 2021, 5:33:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LizardQueen
United States
Re: Glass wall
Thanks. Will try. Will post again with how it came out.
[Aug 24, 2021, 9:09:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LizardQueen
United States
Re: Glass wall
Didn't come out quite right. I put in a wall, then put in the window and made it big enough to take up the whole wall (height & length wise). Looks pretty good.
[Aug 24, 2021, 10:09:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
reddy.shyam
Re: Glass wall
Well done there! As long as things work, all is good. :)
As far as I am aware, we cannot put a window without a wall. So yes, making window as big as wall, sounds like an idea solution to us newbies. :D
Let's see if experts have a better solution.
[Aug 24, 2021, 3:39:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Glass wall
When importing a new model, mark it as Doors/Windows and you can insert in a wall.
In the attached files, you can find several transparent boxes. Combine your preferred colour with normal boxes (or low walls) to construct your own windows. Export, import and mark as Door/Window.
[Aug 24, 2021, 4:53:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
reddy.shyam
Re: Glass wall
Thanks hansmex. Will remember the tip. :)
[Aug 25, 2021, 12:24:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
