Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Glass wall |
| Print at Sep 6, 2026, 5:51:36 AM | View all posts in this thread on one page |
| Posted by LizardQueen at Aug 23, 2021, 8:37:01 AM |
Glass wallIs there a way to make a glass wall? I am trying to make a conservatory/greenhouse. |
| Posted by reddy.shyam at Aug 23, 2021, 5:33:57 PM |
Re: Glass wall Take a glass window object and modify to take make the borders invisible. That should do I believe. |
| Posted by LizardQueen at Aug 24, 2021, 9:09:43 AM |
Re: Glass wall Thanks. Will try. Will post again with how it came out. |
| Posted by LizardQueen at Aug 24, 2021, 10:09:50 AM |
Re: Glass wall Didn't come out quite right. I put in a wall, then put in the window and made it big enough to take up the whole wall (height & length wise). Looks pretty good. |
| Posted by reddy.shyam at Aug 24, 2021, 3:39:34 PM |
Re: Glass wall Well done there! As long as things work, all is good. :) As far as I am aware, we cannot put a window without a wall. So yes, making window as big as wall, sounds like an idea solution to us newbies. :D Let's see if experts have a better solution. |
| Posted by hansmex at Aug 24, 2021, 4:53:46 PM |
Re: Glass wall When importing a new model, mark it as Doors/Windows and you can insert in a wall. In the attached files, you can find several transparent boxes. Combine your preferred colour with normal boxes (or low walls) to construct your own windows. Export, import and mark as Door/Window. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by reddy.shyam at Aug 25, 2021, 12:24:46 PM |
Re: Glass wall Thanks hansmex. Will remember the tip. :) |
Current timezone is GMT Sep 6, 2026, 5:51:36 AM |
