Total posts in this thread: 8
Previous Thread This topic has been viewed 5150 times and has 7 replies Next Thread
stelvio.rosset
Finland
Angled Windows
Hello all, any suggestion how to create angled window?
Example:
Thanks for help.
[Mar 13, 2021, 11:45:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Re: Angled Windows
I made couple angled windows with Sketchup Make 2017 (still free, I think). Those windows available if wanted.
No idea how to create such with SH3D.
Seppo
[Mar 14, 2021, 10:34:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Re: Angled Windows
.. hope I understood correctly your sketch.. smile
[Mar 14, 2021, 10:39:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stelvio.rosset
Finland
Re: Angled Windows
Hi Seppo, yes you got exactly the idea. Do you think I can import your model, if possible, into sh3d?
[Mar 14, 2021, 11:00:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Re: Angled Windows
Smaller window and bigger window.
Both are in .DAE -format so you can use Import Furniture to get them into SH3D.
Inside and outside surfaces are different material so you can use different 'paint' for inside and outside parts.
[Mar 14, 2021, 11:51:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Re: Angled Windows
Rendering these windows might show unwanted colors/materials 'cladding_stucco_white' and 'material' bleeding through.
In this case use Modify furniture - Materials and make those materials invisible.
I have not found other solution to remove them.. sorry
[Mar 15, 2021, 10:24:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
Re: Angled Windows
using the shape generator plugin you can create your own window shape, set his opacity, then, export it as an obj file
Shape Generator 1.2
Then you could add some boxes around it as the window frame.
Export all the selection as an obj file
Import the new obj file as a door on window
and VOILÀ
[Apr 16, 2021, 3:48:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Re: Angled Windows
Excellent solution, crackwood01 applause
- uses only SH3D-tools AND
- avoid all problems I mentioned when creating window with SketchUp
This is the way I will make my windows!
[Apr 26, 2021, 9:35:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
