Print at Sep 20, 2026, 6:09:36 PM View all posts in this thread on one page
Posted by stelvio.rosset at Mar 13, 2021, 11:45:37 AM
Angled Windows
Hello all, any suggestion how to create angled window?
Example:
Thanks for help.
Posted by SeppoV12 at Mar 14, 2021, 10:34:23 PM
Re: Angled Windows
I made couple angled windows with Sketchup Make 2017 (still free, I think). Those windows available if wanted.
No idea how to create such with SH3D.
Seppo
Posted by SeppoV12 at Mar 14, 2021, 10:39:16 PM
Re: Angled Windows
.. hope I understood correctly your sketch.. smile
Posted by stelvio.rosset at Mar 14, 2021, 11:00:36 PM
Re: Angled Windows
Hi Seppo, yes you got exactly the idea. Do you think I can import your model, if possible, into sh3d?
Posted by SeppoV12 at Mar 14, 2021, 11:51:44 PM
Re: Angled Windows
Smaller window and bigger window.
Both are in .DAE -format so you can use Import Furniture to get them into SH3D.
Inside and outside surfaces are different material so you can use different 'paint' for inside and outside parts.
Posted by SeppoV12 at Mar 15, 2021, 10:24:25 AM
Re: Angled Windows
Rendering these windows might show unwanted colors/materials 'cladding_stucco_white' and 'material' bleeding through.
In this case use Modify furniture - Materials and make those materials invisible.
I have not found other solution to remove them.. sorry
Posted by crackwood01 at Apr 16, 2021, 3:48:59 AM
Re: Angled Windows
using the shape generator plugin you can create your own window shape, set his opacity, then, export it as an obj file
Shape Generator 1.2
Then you could add some boxes around it as the window frame.
Export all the selection as an obj file
Import the new obj file as a door on window
and VOILĂ€
Posted by SeppoV12 at Apr 26, 2021, 9:35:39 PM
Re: Angled Windows
Excellent solution, crackwood01 applause
- uses only SH3D-tools AND
- avoid all problems I mentioned when creating window with SketchUp
This is the way I will make my windows!
