Total posts in this thread: 5
Previous Thread This topic has been viewed 1593 times and has 4 replies Next Thread
fixxser
PhotoVideoRendering-1.9 plug-in Ubuntu plugin memory leak
I have installed the PhotoVideoRendering-1.9 plug-in in Ubuntu 18.04
Sweet Home 6.2 and 6.1 both
When rendering a video, the memory keeps going up and up until the PC runs out of memory and crashes.
Is there something I could do or try? Maybe change some lines of code?
The regular video rendering works fine. 24 hours rendering, I am willing to wait.(1280x720)
[Apr 22, 2020, 4:48:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: PhotoVideoRendering-1.9 plug-in Ubuntu plugin memory leak
Maybe, you could try to increase the max memory used by Sweet Home 3D?
[Apr 22, 2020, 9:39:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@fixxser
If it is a memory problem, increasing it should be enough.
As the problem only occurs with the plug-in, I would like to know your rendering settings: (rendering engine and its properties, sky lighting enabled or not).
Does it recur whatever the resolution or only for 1280x720 ?
EnkoNyito
[Apr 23, 2020, 5:11:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jirka81
Česká republika
I have problem with YafaRay engine too:
when I start rendering, a lot of text is logged into the console and then nothing happens - nothing is rendered.
But sometimes it works without problems.
I think it gets stuck before it has log this
[16:33:14] INFO (+ 1s): Environment: View number = 0, view name: '', camera name: '5b3b3366-0813-49fd-b31a-250e4ba96d35'
[16:33:14] PARM: Using [4] Threads.
[16:33:14] PARM: Using for Photon Mapping [4] Threads.
[16:33:14] INFO: Kd-Tree: Starting build (7945647 prims, cr: 0.8 eb: 0.33)
[16:33:42] INFO (+ 28s): Scene: total s ....
With engine Sunflow is rendering working perfect, but with YafaRay sometimes not start rendering, sometimes java crash.
I use linux and 64b java with -Xmx4g.
And I have to admit that my file is big (180MB), but Sunflow has no problem with that.
PS: I am sorry for my english
[Apr 24, 2020, 5:54:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@jirka81
To work around the problem of not deleting the lights after their creation in YafaRay, I found this solution which recreates the scene with each video frame.
For the moment, without this solution, no video rendering is possible with YafaRay.
EnkoNyito
[Apr 24, 2020, 8:40:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
