Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Rendering Issue if open more than one flat |
| Print at Sep 20, 2026, 8:46:32 AM | View all posts in this thread on one page |
| Posted by MichaelN at May 21, 2019, 8:05:24 PM |
Rendering Issue if open more than one flat Is there a known issue when opening a second file / flat? 3D view works, but the 2D screen shows red squares instead of the common furnitures view. see https://we.tl/t-grkGO5Ssaz |
| Posted by bdfd at May 21, 2019, 9:39:50 PM |
Re: Rendering Issue if open more than one flatAnd ??? What is the configuration of your PC ? . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at May 22, 2019, 11:48:09 AM |
Re: Rendering Issue if open more than one flat This sounds like a memory problem. What memory use is indicated in the About dialog? Did you try to increase the max memory if possible? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MichaelN at May 22, 2019, 9:05:54 PM |
Re: Rendering Issue if open more than one flat OK, I created such a ini file with 1000M (tried 1200M, but SH3D doesn't start anymore) and SH3D uses 0,5-0,6 GB of 0,9 GB - red squares :-( Is 900 MB the maximum? My PC is a HP spectre with 16 GB RAM and two 4k Monitors (1 generic, 1 via DisplayLink) @Win10 64bit |
| Posted by Puybaret at May 23, 2019, 2:55:20 PM |
Re: Rendering Issue if open more than one flat Run the installer again and select the 64 bit architecture in the screen that lets you choose the installation folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MichaelN at May 28, 2019, 7:46:31 PM |
Re: Rendering Issue if open more than one flat THX, that helps. Now I have V6.1.2 and this installer has an option to choose between 32 and 64 bit. With 64bit the rendering works fine. |
Current timezone is GMT Sep 20, 2026, 8:46:32 AM |
