Print at Sep 20, 2026, 11:46:42 AM
Posted by MichaelN at May 21, 2019, 8:05:24 PM
Rendering Issue if open more than one flat
Is there a known issue when opening a second file / flat?
3D view works, but the 2D screen shows red squares instead of the common furnitures view.
see https://we.tl/t-grkGO5Ssaz
Posted by bdfd at May 21, 2019, 9:39:50 PM
confused   Re: Rendering Issue if open more than one flat
And ??? biggrin
What is the configuration of your PC ?
Posted by Puybaret at May 22, 2019, 11:48:09 AM
This sounds like a memory problem. What memory use is indicated in the About dialog? Did you try to increase the max memory if possible?
Posted by MichaelN at May 22, 2019, 9:05:54 PM
OK, I created such a ini file with 1000M (tried 1200M, but SH3D doesn't start anymore) and SH3D uses 0,5-0,6 GB of 0,9 GB - red squares :-( Is 900 MB the maximum?
My PC is a HP spectre with 16 GB RAM and two 4k Monitors (1 generic, 1 via DisplayLink) @Win10 64bit
Posted by Puybaret at May 23, 2019, 2:55:20 PM
Run the installer again and select the 64 bit architecture in the screen that lets you choose the installation folder.
Posted by MichaelN at May 28, 2019, 7:46:31 PM
THX, that helps. Now I have V6.1.2 and this installer has an option to choose between 32 and 64 bit. With 64bit the rendering works fine.
