Print at Aug 19, 2026, 8:19:16 AM
Posts: 200   Pages: 20   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Posted by bdfd at Oct 2, 2016, 8:21:36 AM
Re: 2040 : Mars Two
Here technical specifications of habitation module v2.
1900 x 1400 in Q4 without R1.3.1
If a storm occurs (I saw the movie 'The martian'), an anti-tilt system is set up.
4 cables out of the fifth floor (light gray, base of roof) and will be planted in the ground (like harpoons) ...
This module has five levels (with descent engines).
1st : Airlock and a rear cargo
2nd : technical part
3rd : living and sick bay
4th : bedrooms
5th : roof (upper airlock, antennas, parachutes, ...)
It can support 11 people ! smile
It is equipped with 4-wheel drive to adjust its position.
Posted by bdfd at Oct 3, 2016, 8:40:39 AM
Re: 2040 : Mars Two
D 188 : The D Day !
Departure begins...
1920 x 1024 in Q4 without R1.3.1
All 11 members of crew are aboard.
Look at simply inside MRV v2 :
4 in cockpit and 7 under head (lying 45 °).
side view
The order to come in :
The three first passengers in lower armchairs,
The next four in upper armchairs,
The two external astronauts in cockpit and finally
The chief and the pilot in last (central location)...
Red : air lock,
Grey : Dashboard,
Green : cockpit,
Blue : 7 Passengers (2 lines of 3 + 4 at different height.
Yellow : technical storage,
Dark blue : life support,
Purple (rear red) : toilets,
Rose : technical part,
Cyan : engines & tanks
Brown : main thrusters
Posted by Puybaret at Oct 3, 2016, 11:25:02 AM
Re: 2040 : Mars Two
Passengers must be impatient to land! Good idea to use transparency for such a small space wink
Posted by bdfd at Oct 3, 2016, 5:05:40 PM
Re: 2040 : Mars Two
A hot moment for the crew and 30 mn after the Space center on Earth...
1024 x 800 in Q4 without R1.3.1
Heat shield is gone, like MRV the temperature descents, parachutes are open !
Posted by bdfd at Oct 4, 2016, 7:58:02 AM
Re: 2040 : Mars Two
Slowly crew arrives on martian ground...
Posted by MartinSK at Oct 4, 2016, 8:04:21 AM
Re: 2040 : Mars Two
Wow...
"hot moment picture"...looks really really great...
Posted by bdfd at Oct 4, 2016, 11:22:01 AM
Re: 2040 : Mars Two
Touch Down ! smile
"Hello Earth, Condor is on Mars ! "
Quicky from Hermes... applause applause applause
30 mn later from Earth... applause applause applause
Posted by VeroniQ at Oct 4, 2016, 5:08:43 PM
Re: 2040 : Mars Two
Hurrah! Is the whole crew alive?
Posted by bdfd at Oct 4, 2016, 9:34:36 PM
Re: 2040 : Mars Two
Yes, but some jerseys well sweat ! laughing
Here is the First interior view of this project. smile
1024 x 768 in Q4 without R1.3.1
Light is green, the second astronaut prepares his output from air lock...
Their priorities :
1. Prepare Habitation module,
2. Install Solar modules,
3. Go out the rover to take all members of crew...
Posted by bdfd at Oct 5, 2016, 8:40:14 AM
Re: 2040 : Mars Two
Here spécifications of MRV.
1900 x 1400 in Q4
O.S.S. will be detailled later.
