Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Adequate memory usage |
| Print at Oct 6, 2026, 5:55:25 AM | View all posts in this thread on one page |
| Posted by BLAlley at Mar 20, 2013, 4:17:10 AM |
Adequate memory usage I like the program, but it needs to use more memory than 540MB. It is, after all, a 3d graphics program. 540 isn't enough to work on his res photos. Either that, or let it use my graphics card, which is wasted. I know there is a way to get a GB of usage, but the instructions don't actually explain how to format the code in the .ini file. Is that coming? I'd gladly pay if I can use it to model more than a box. |
| Posted by hansmex at Mar 20, 2013, 7:09:22 AM |
Re: Adequate memory usage Please, read this section in the FAQ: How can I adjust the memory used by Sweet Home 3D? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by BLAlley at Mar 20, 2013, 3:42:46 PM |
Re: Adequate memory usage I read that, but don't understand how to enter the code in the file. |
| Posted by hansmex at Mar 20, 2013, 3:49:47 PM |
Re: Adequate memory usage Which operating system are you using? Windows, Mac, Linux? And how much memory do you want SH3D to use? H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by BLAlley at Mar 20, 2013, 3:51:08 PM |
Re: Adequate memory usage Windows 7 |
| Posted by BLAlley at Mar 20, 2013, 3:51:51 PM |
Re: Adequate memory usage I'd like to use as much as possible. My comp has 4GB right now. |
| Posted by hansmex at Mar 20, 2013, 4:32:22 PM |
Re: Adequate memory usage Use the attached file, and store it where the FAQ tells you. Restart SH3D and it should work, allowing close to 2GB of memory for SH3D. Hans ---------------------------------------- ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by BLAlley at Mar 20, 2013, 5:02:17 PM |
Re: Adequate memory usage Now it won't start. "Could not create the Java virtual machine" |
| Posted by Puybaret at Mar 20, 2013, 5:03:25 PM |
Re: Adequate memory usage I would love to set as much memory as possible but fear this old bug could occur again. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 5:55:25 AM |
