Print at Oct 6, 2026, 6:55:13 AM
Posted by BLAlley at Mar 20, 2013, 4:17:10 AM
Adequate memory usage
I like the program, but it needs to use more memory than 540MB. It is, after all, a 3d graphics program. 540 isn't enough to work on his res photos. Either that, or let it use my graphics card, which is wasted.
I know there is a way to get a GB of usage, but the instructions don't actually explain how to format the code in the .ini file.
Is that coming? I'd gladly pay if I can use it to model more than a box.
Posted by hansmex at Mar 20, 2013, 7:09:22 AM
Re: Adequate memory usage
Please, read this section in the FAQ:
How can I adjust the memory used by Sweet Home 3D?
Posted by BLAlley at Mar 20, 2013, 3:42:46 PM
I read that, but don't understand how to enter the code in the file.
Posted by hansmex at Mar 20, 2013, 3:49:47 PM
Which operating system are you using? Windows, Mac, Linux?
And how much memory do you want SH3D to use?
Posted by BLAlley at Mar 20, 2013, 3:51:08 PM
Windows 7
Posted by BLAlley at Mar 20, 2013, 3:51:51 PM
I'd like to use as much as possible. My comp has 4GB right now.
Posted by hansmex at Mar 20, 2013, 4:32:22 PM
Use the attached file, and store it where the FAQ tells you.
Restart SH3D and it should work, allowing close to 2GB of memory for SH3D.
Attachment SweetHome3D.l4j.ini (10 bytes) (Download count: 755798)
Posted by BLAlley at Mar 20, 2013, 5:02:17 PM
Now it won't start. "Could not create the Java virtual machine"
Posted by Puybaret at Mar 20, 2013, 5:03:25 PM
I would love to set as much memory as possible but fear this old bug could occur again. sad
