Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem by making photo |
| Print at Aug 15, 2026, 4:18:59 PM | |
| Posted by mr3d at Feb 18, 2013, 5:35:29 PM |
Problem by making photo Hello: I upgraded from v3.6 to 3.7, and I improved a project that before making photos on all trim levels, but now at level 3 and 4 to take part after the picture taken, the picture stop. What I can do? Thank you. |
| Posted by Puybaret at Feb 18, 2013, 5:52:36 PM |
Re: Problem by making photo You should try to increase the maximum amount of memory Sweet Home 3D can use. Please look at the FAQ How can I adjust the memory used by Sweet Home 3D? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mr3d at Feb 18, 2013, 8:32:07 PM |
Re: Problem by making photo I have the NVidia Geforce 560ti with 1,25mb. In the NVidia control panel I have chosen the maximum performance instead maximum quality and in the 3th level works sometimes but in level 4th never. Thanks |
| Posted by Puybaret at Feb 18, 2013, 10:24:34 PM |
Re: Problem by making photo Adjusting the settings of your video card is useless because it's not used at all to compute images at the quality levels 3 and 4. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mr3d at Feb 19, 2013, 9:43:34 PM |
Re: Problem by making photo All work ok. Thanks. I have download the JAVA for 64bits, and then the JAVA downloader of sweethome, and works perfectly. Thanks a lot. |
Current timezone is GMT Aug 15, 2026, 4:18:59 PM |
