Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Cut out |
| Print at Sep 6, 2026, 6:14:55 AM |
| Posted by quickmic at Feb 11, 2011, 6:29:48 PM |
Cut out Hello First a big thanks for this program, but I have a problem. I need a kind of cut-out-tool to make holes in a wall with angle and without a frame. I need this for my top floor flat, so is there anything I can use? thx |
| Posted by Puybaret at Feb 11, 2011, 7:13:02 PM |
Re: Cut out Import the invisible box selecting the Door or window option during the 3rd step, and use one or more boxes of this kind to cut any wall or group of walls (it will cut only walls). See also this discussion. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by quickmic at Feb 11, 2011, 7:55:17 PM |
Re: Cut out Hmm, I implement the invisible box, but after small test it doasn't solve my problem. I will check the thread... thx |
| Posted by hansmex at Feb 11, 2011, 9:17:20 PM |
Re: Cut out Mic, Maybe this invisible hatch will solve your problem? And eh, don't forget to check Door/Window while importing, or it won't insert itself in the wall. Hans ---------------------------------------- ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by quickmic at Feb 13, 2011, 9:10:28 AM |
Re: Cut out Now it works basically. check Door/Window while importing... was my mistake, thx for the hint Problem is, I need an invisible wall/box or whatever which can make an angle on the top. Same system as normal wall have...sloping wall. Is this possible? |
| Posted by hansmex at Feb 13, 2011, 11:19:12 AM |
Re: Cut out Mic, Maybe you can apply a transparent texture to (a part of) the wall? It will show up as black in the design, but will be invisible when you make a photo render. Hans ---------------------------------------- ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by wrosun at Feb 13, 2011, 11:54:58 AM |
Re: Cut out Problem is, I need an invisible wall/box or whatever which can make an angle on the top. Same system as normal wall have...sloping wall. Is this possible? Are you trying to do something like this???? ![]() Design created by Macfrog Click to browse to the Original thread if it is so then its quiet simple...? let me know if its the same thing you are trying to do or not?? |
| Posted by quickmic at Feb 13, 2011, 3:36:51 PM |
Re: Cut out Something like this.... The red area has to be removed. ![]() |
| Posted by quickmic at Feb 13, 2011, 3:39:36 PM |
Re: Cut out That are dormers. |
| Posted by hansmex at Feb 13, 2011, 4:40:17 PM |
Re: Cut out Mic, Share your design, or send it to me. I don't understand exactly what you want. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 6:14:55 AM |
